Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  4
Results 1 to 12 of 12
Thread: Low speed wobble
    Mar 2023
    East Palatka Florida USA
    Default Low speed wobble
    Hi everyone new to forum and trikes. Have a 2010 harley flhxxx and at speeds under 25 mph and uneven or just rough pavement the front wheel shakes really bad until you get the bike stoped. All New tires.any help would greatly appreciated
    80+ Posts
    Aug 2016
    sebastian FL
    Steering damper could be shot, neck bearings could be loose, or both.
    Definitely not normal.
    Hi Duane, to Trike Talk and your first post
    So, did your trike ride OK before new tires?
    Quote Originally Posted by Jiffypop954 View Post
    Dwane… Welcome to Trike Talk…👍 Is this something new happening Or before you got new tires ..?
    Mar 2023
    It's been that way since I got it from the Harley dealer. Had them look into the problem and the response I got was It's normal. Would try a new stabilizer but big $$$$ just to test. Going to do the fall away test this weekend Thanks for all the help
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Not normal. If its an Ohlins stabilizer they will rebuild it. Jack up the front end and with a mechanics stethoscope ( cheap at Harbor Freight) listen at the axle area while turning the wheel. Odd metal on metal or grinding noise is bad wheel bearings. Check brake rotor runout with a dial caliper ( clamp on one at HF reasonable price) then as mentioned check the neck bearings.Also examine your wheels carefully for cracks- spray some window cleaner on them and look for seeping. Your dipshit dealer should have performed these tests.
    750+ Posts
    Jan 2010
    east windsor ct
    bearings on 3 wheels need to be a tad tighter than the standard 2 wheel fall away
    Just another thought check the front of the engine front cylinder top of the head there’s a stabilizer link it’s called a Tie link. Check the bolts that hold it sometimes they will loosen up or even sheer off the bolts had that on my 11 Triglide if I remember correctly they are 9/16 bolts ……….
    But that was such a common problem the Harley dealership should have noticed that if they were bad, Is there a possibility?? when you hit a rough patch of road you put the death grip on the handle bars and magnifies the wobble situation you might have to ease up a little bit on your grip ?..
    Just to add after rereading your original post I realize this is your first three wheeler ? I would think that the death grip is probably the problem. I don’t think Harley Dealers are that incompetent where they can’t find a mechanical problem.
  11. #10
    100+ Posts
    Jun 2022
    South Carolina
    If the steering head bearings have not been serviced since 2010, it is definetly time to inspect, repack or replace them.
    US Navy Veteran
    Airframe and Powerplant Mechanic 43 years
    1989 FLSTC
    2019 FLHT
    2022 Tri Glide
  12. #11
    150+ Posts
    Apr 2018
    Cordes Lakes, AZ
    LOL
  13. #12
    Quote Originally Posted by Teufelhunde View Post
    LOL
    Yea..Maybe I should have reworded that…🤔-😁..
  1. DNA kit..low speed wobble
    By fat rat in forum Harley Trike Conversions
    Last Post: 02-03-2022, 04:49 PM
  2. Replies: 10
    Last Post: 07-23-2020, 04:30 PM
  3. Replies: 8
    Last Post: 07-22-2020, 09:47 PM
  4. Low Speed Wobble
    By fatboy in forum Harley Trike Conversions
    Last Post: 07-17-2014, 01:28 PM
  5. Low Speed Wobble
    By Alan Oakley in forum General Discussion
    Last Post: 11-19-2010, 05:17 PM
