Likes Likes:  14
Results 1 to 11 of 11
Thread: Erratic Reverse Motor Operation… Is The End Near?
    150+ Posts hydraglide's Avatar
    Dec 2021
    Woodridge,Il USA
    Default Erratic Reverse Motor Operation… Is The End Near?
    I picked up my TriGlide a few days ago from my dealer after having some winter work done.
    The first time I engaged reverse, I felt the customary “lurch”, then there was a pause (note I never took my thumb off of reverse engagement) then it “lurched” again and continued to back up normally.
    Hmmmm… duly noted. Didn’t do it again the next time I engaged reverse (at home, as a test).
    Today, reverse behaved normally (I need it to back out of my garage. Once I’m half way out the garage, with the driveway on a downward slope, I disengage reverse and let natural physics take over).
    After a nice 200 plus mile ride, I stopped by my dealer and when I attempted to back it into a parking space, same issue. With my thumb on the reverse engagement button, it “paused” then continued in reverse.
    When I got home (on flat ground) I tried engaging reverse a few times and I had an instance when it “paused”, but did not continue to back up.
    I continued to press the reverse engagement button for like 5 seconds… nothing. Reverse “R” light was solid (no blinking). I took my thumb off the button then pressed down again and it immediately “lurched” and acted fine.
    I’m suspecting my reverse motor is not long for this world. It’s under an extended warranty so I’m covered, but… thought I’d ask you all to get some opinions.
    A mechanical reverse isn’t in the picture since I have the extended warranty. I’m just looking to see if anyone else has experienced the symptoms described and if they found a solution.
    My guess is the solution is replacing the reverse motor.
    And also, reverse is something I need and use. I don’t “abuse it”, but I “use it”.
    Thanks in advance everyone!
    Live Everyday Like It's Your Last... Because One Day It Will Be...
    2021 Billiard Red Tri-Glide • 1999 Ultra Classic - Stage 2, 6 Speed (Gone) • 1995 Softail Nostalgia (Gone) • 1977 Superglide - Chopped (Gone)
    • 1976 Liberty Edition Sportster (Gone) • 1949 Hydraglide Panhead - Fully Restored (Gone)
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Warranty will not pick up till it dies . I’ve been wrong before , but I think that’s how the program works .
    800+ Posts woody's Avatar
    Jul 2012
    Talladega,Al 35160
    Quote Originally Posted by 1dn5up View Post
    Tell them it died and you had to push but it started back to working but it is not working right. After they replace it ask if you could have the old one back. I did that and I was told it had to be turned in for warranty but when I picked up my bike it was in the tour pack. I took it apart and cleaned the brushes and holders. so I would have a spare for when the warranty was gone.
    2019 Goldwing CSC
    Dec 2021
    Woodridge,Il USA
    I'll find out next week! It's either the motor, switch or wiring... But something ain't working right! Switch would be the easiest thing to swap out and try first, IMO.
    Contributing Member ROAD DOG's Avatar
    Jan 2009
    MA,
    Thats easy back up a long Steep hill, that will Cook it, They burn up on flat land
  6. DKCustoms postbit
  7. #6
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by ROAD DOG View Post
    This is what I would do, cook it and get the warranty to replace it
    It is for sure a weak link by HD IMO
  8. #7
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Quote Originally Posted by woody View Post
    And now ya go rid of the Harley. You can donate the started to me at MV & I would be very happy. I would rebuild for a spare .lol
    2020 TriGlide Tahitian Teal aka (Hawaiian Hussy). Avon frt & Comfortred rear tires. ProAction frt & rear susp. RZ seat. DK floorboard extension & rear axle retainer kit with EBS, HD pull -back bars. Custom Dynamics front turn signals & Vent grill. All ,HD "Edge Cut " accessories.
  9. #8
    100+ Posts Koolbreeze's Avatar
    Oct 2018
    Stewartstown, PA, USA
    How old is your battery?
    May have the voltage but the Amperage may be getting lower if the battery is 3 or more years old.
    May be worthwhile to get it load tested.
  10. #9
    Dec 2021
    Woodridge,Il USA
    Quote Originally Posted by Koolbreeze View Post
    2nd season... but worth doing anyway. I will suggest that is done when I bring it in next week.
  11. #10
    Dec 2021
    Woodridge,Il USA
    Update… my dealer replaced the reverse motor under warranty, even thought it wasn’t “completely” DOA.
    It acted up on demand when I brought it in for service… that’s all they needed to see.
    Road out today… all good to go.
    All’s well in trike land…
  12. #11
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Just rebuilt the reverse motor on my brothers Tri. Lasted 10 years. Instead of getting ass raped by the dealer here's what youll need: OEM Z/M solenoid( save and use your old plunger) for reverse motor 83388-09/9A. Reverse motor armature and brush holder w/ brushes. You can find them on Fleabay for a total cost of around $ 120.00+-.The plunger is proprietary and HD doesnt sell it separately - at least thats what I was told.
  1. erratic guage
    By miabobo in forum Honda Trikes
    Last Post: 04-22-2019, 12:18 PM
  2. surging and erratic running
    By cinjeff in forum Honda Trikes
    Last Post: 10-03-2018, 12:06 AM
  3. CB operation 2012 TriGlide
    By nevtat in forum Harley Tri Glide
    Last Post: 01-14-2018, 11:50 AM
  4. Erratic RPMs
    By Tricycleman in forum Honda Trikes
    Last Post: 10-04-2017, 03:59 PM
