Speed Bleeders
Likes Likes:  13
Thanks Thanks:  1
Results 1 to 16 of 16
Thread: Front Rotors heating up, burned up six rotors so far
    5+ Posts
    May 2019
    Toronto, Ontario Canada
    Default Front Rotors heating up, burned up six rotors so far
    2018 Tri-glide with linked brakes. Had issues since nearly new. Replaced rotors three times, pads, many times, master cylinder and still after a few thousand km one or the other front rotors will over heat and eventually warp.
    Dealer and my loyal indy have not been able to cure this issue.I use both front and rear brakes all the time. fluid is good and has been changed a couple of times.
    Trying to find out if there are others out there who have suffered this wicked issue.....
    Currently bike otherwise in excellent condition.
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Have they checked the calipers?
    Possible problem they are not releasing completely, also front hoses could be internal collapsing causing calipers to not release completely
    Go for a ride, after returning, pump the front brakes a couple times, crack the front caliper bleeders, does fluid stream out?
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    My 17 has done the same thing, and here is how cured it. I removed one caliper at a time, then removed the pads. Find a block of wood or something that will go between one set of pistons at a time. then slowly pump the front brakes until the pistons move out about a 1/4 inch. Using a soft toothbrush and brake cleaner, spray the piston and scrub all around it a couple times. then clean with a paper towel. Then using a disc brake grease apply a small amount of grease to the piston, then press it back in. Then pump it out again to make sure it doesn't stick.
    Do this to both front pistons which are the larger pistons, once you have cleaned all 4 pistons you can move to the two smaller pistons that set between the bigger pistons. These are the rear brake pistons that are actuated when you apply the rear brakes. I had to do this in the parking lot of a motel when I was in Cherokee NC. So now this is something I do every spring.
    650+ Posts Notgrownup's Avatar
    Oct 2021
    Snow Hill NC USA
    Your calipers should’ve been changed under warranty
    Be who your dog thinks you are.
    2021 Tri Glide Ultra Vivid Black with some Farkles.
    5+ Posts
    May 2019
    Quote Originally Posted by Notgrownup View Post
    Dealer would not warranty caliper on new bike, go figure.
  6. DKCustoms postbit
  7. #6
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Quote Originally Posted by TOHOG View Post
    That is complete nonsense, a new bike has fender to fender warranty EXCEPT for wear items like brake pads
    Even extended warranty covers calipers
  8. #7
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Harley-Davidson Customer Care: 1-800-258-2464
  9. #8
    5+ Posts
    May 2019
    Quote Originally Posted by Old Road Dog View Post
    You think there is any hope after extended warranty has passed?
  10. #9
    100+ Posts
    Jun 2022
    South Carolina
    It could be the brake hose from the MC has failed internally, this happens a lot on cars and trucks.
    Item 9 in the illustration:
    https://www.harley-davidson.com/us/e...dc865bdd9d72/y
    US Navy Veteran
    Airframe and Powerplant Mechanic 43 years
    1989 FLSTC
    2019 FLHT
    2022 Tri Glide
  11. #10
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Did you have it documented with your dealer? If so its a non resolved issue. What do you have to lose?
  12. #11
    5+ Posts
    May 2019
    Dealer got pissed because I did not accept their explanation that it had to be my fault. They finally gave me my money back and asked me to never come back. So, now that warranty period is exhausted and they have kicked me out of Dlrship ...... what????
  13. #12
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Quote Originally Posted by Dan SC View Post
    This is what happened to my '99 F150. Had me stumped until I remembered that we had to change out the hydraulic hoses for the recuperator on our 155mm self propelled howitzers. Orders came down to change from cherry juice ( hydraulic fluid) to lemon juice. 6 months later the hoses were collapsing internally. So it was back to cherry juice.
  14. #13
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Than you should have paper that says it was not resolved as Old Road Dog stated. I would explain Mother Harley as you have here, including the last episode with your dealership. You may get it fixed since it happen under warranty, which will be great! If not, you're not any worst off than you are now. Maybe some of the solutions mention here will solve the problem and you can mention them to the dealership/or do them.
    HOW CAN YOU HELP THE TRIKE TALK FORUM? Become a GOLD CLUB MEMBER!
    A veteran - whether active duty, retired, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to the 'United States of America', for an amount of 'up to and including my life.'
  15. #14
    5+ Posts
    May 2019
    Quote Originally Posted by nucseal View Post
    Thanks for the follow-up. I was on HOLD with H-D for 40 mins this morning.... had to hang up. BUT do appreciate ALL the responses from those here. Encouragement and some things to check helps.
    I have reviewed the emails and the "kiss-off" from the original dealer and am prepared to put forth a good effort with the MOCO.
    I will keep the forum updated.
    Also
    All suggestions have been passed on to my Indy (harley trained) who is in my corner. He is working on the calipers now to thoroughly clean and check them out as well as check out the lever position to make sure it is somehow causing the brakes to be on when I am not on the lever.
    Spring has finally come to Toronto and my bike is in the shop .... back to yard clean I guess for the next day or so.
  16. #15
    3750+ Posts
    PosseRider's Avatar
    Jan 2016
    Dayton, Ohio
    Sounds like a sad-ass Dealer,,, Let everyone know who he is & the type of service he gives. & find another dealer... Definitely worth a call to HD..
    2020 TriGlide Tahitian Teal aka (Hawaiian Hussy). Avon frt & Comfortred rear tires. ProAction frt & rear susp. RZ seat. DK floorboard extension & rear axle retainer kit with EBS, HD pull -back bars. Custom Dynamics front turn signals & Vent grill. All ,HD "Edge Cut " accessories.
  17. DKCustoms postbit
  18. #16
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Also
    Dont tell the MOCO your using an Indy.
  1. Burned on rain gear
    By jc1300 in forum Harley Tri Glide
    Last Post: 09-20-2018, 05:34 PM
  2. Burned All the Winter Storage Gas Out
    By lgjhn in forum General Discussion
    Last Post: 03-11-2018, 07:26 PM
  3. Right Headlight burned out
    By Baldy_54 in forum Honda Trikes
    Last Post: 08-10-2017, 08:36 PM
  4. Six Weeks and Counting
    By QC Goldwinger in forum New Member Introductions
    Last Post: 07-23-2008, 07:14 AM
