Likes Likes:  3
Results 1 to 7 of 7
Thread: 2013 Stallion Trike Fuel pump replacement
    Feb 2015
    Rockport, TX. USA
    Default 2013 Stallion Trike Fuel pump replacement
    Has anyone changed your fuel pump on a 2013 Stallion Trike? How do you get to it?
    Sheila, I have not nor have I heard of anyone doing it. But it does look like it would be a real challenge. If you can get the gas tank to drop a few inches you should be able to work the pump out of the top of the gas tank.
    If this is a typical Ford Ranger type pump you will ( if it does not have an access plate) have to lower the tank to R and R the pump
    You can in most cases get just the pump, tho I would get the entire module so you have no surprises when done
    I have changed a lot of pumps, not a lot of fun but doable if you have the tools and patience
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    I wonder if it has an impact sensor like the cars and trucks. If it does it's the first place I would look they like to pop that switch. I've also seen plug melted on that switch.
    They should have the Inertia switch if the wiring is a Ford Ranger
    In this thread
    https://www.triketalk.com/forum/thre...witch?p=875219
    Yes it does.
    The switch is a RED button under the seat towards the right middle near the fuse panel.
    Yes the tank has an access panel, but the tank is so far up inside the body behind the rear seat back that getting the panel off and the pump out is an issue. If you can get the tank to drop down enough, then it should be able to be removed.
    Good call to try the reset first. It did go off once on us after an emergency stop.
    450+ Posts rocket1lf's Avatar
    Dec 2013
    Hot Arizona, USA
    Mine has tripped a few times going over a pothole or bouncing the bottom coming out of a driveway slowly. Doesn't take a lot to pop it. I would definitely check that before fooling with the fuel pump. I haven't heard of anyone needing to replace the fuel pump. Rick
    Stallion #378
    Suzuki Burgman 650
  1. Stallion fuel pump
    By Bama boy in forum Stallion Trikes
    Last Post: 03-28-2024, 08:48 AM
  2. Stallion water pump 2013
    By angel12364 in forum Stallion Trikes
    Last Post: 10-11-2022, 06:02 AM
  3. where's fuel pump ht1500 r/m trike
    By eagle1 in forum Roadsmith Trikes
    Owners Forum
    Last Post: 11-24-2019, 06:13 PM
  4. Ok,Gravity or electric fuel pump?
    By warnerrd in forum VW Powered Trikes
    Last Post: 10-15-2010, 10:46 PM
Tags for this Thread
