Likes Likes:  39
Thanks Thanks:  7
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 21 to 40 of 56
Thread: Air cleaner
  1. #21
    100+ Posts rcappie's Avatar
    Oct 2019
    La Porte
    Like I said…..All it needed was to put a few miles on it..��
    Thanks for your advice sir. Now figure out how I want to do an external breather and I’m good to go.
  2. #22
    Quote Originally Posted by rcappie View Post
    D K Customs, call: 662.252.8828 ask for Kevin or Dwayne
  3. #23
    Oct 2019
    La Porte
    I made one on the other air cleaner. I’ll probably do the same with this one. We’ll see
  4. #24
    Oct 2019
    La Porte
    Fp3 will get the job done and has tech support
    Hope this all flies good for you now, just for grins check your intake for air leaks
    Start it up and spray some carb cleaner around the intake ports, if your engine speeds up you need to check the intake seals
    Well Jack, things are not better. Took it for a ride and it runs good! After riding idle bumps up to about 1700-2000 hangs there for awhile will not go down shut it off and right at 1000. Should I just start looking for a tuner? Thought my problem was solved. Rich
  5. #25
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Just arrived today. Sitting on my bench is a beautiful S&S cast aluminum 55mm intake for the M8. No more mofo cheap ass plastic intake.
  7. #26
    Check for trouble codes first
    https://www.wilkinsharley.com/--Chec...rley-Davidsons
  8. #27
    Oct 2019
    La Porte
    Checked for codes, found no codes. I even read a post about loose exhaust bolts and tried that. Had a couple loose but not bad. Tightened, made no difference
  9. #28
    This has me stumped, just for grins take the cover off and look @ the throttle plate, then start it with the cover off, see how it behaves
    Also, unplug the connector to the throttle actuator, look closely at the pins, clean them good with alcohol, apply a bit of dilectric grease and plug it back in
  10. #29
    100+ Posts
    Sep 2018
    Martinez, CA, USA
    Agree Jack. If an intake leak has been ruled out something holding the throttle blade open a little is likely especially after changing the air cleaner.
  11. #30
    Oct 2019
    La Porte
    Quote Originally Posted by PanheadSteve View Post
    Thanks, will check and get back to you
  12. #31
    Oct 2019
    La Porte
    Ok guys and gurus, check butterfly nothings blocking. Gasket looks good. After warm up I can hear it surging from like 1000-1050 and that’s at idle. I think I may try putting the old air cleaner on and see how it acts?
  13. #32
    My 2019 triglide idles at about 1000’ ( So did my 2011 and 2017) plus or minus and there’s no way I could tell 50 RPMs up or down unless I install a digital tachometer do you have one installed? And as far as the surging that is the 45° angle of the cylinders… almost like a Harley Davidson trademark.. Many motorcycle companies try to create that surging sound/feel but none successful…
  14. #33
    Oct 2019
    La Porte
  15. #34
    Ooooooooooo
  16. #35
    Look on your LS lower frame leg, I believe the info on idle speed is on a sticker there
  17. DKCustoms postbit
  18. #36
    Oct 2019
    La Porte
    Thank you, by surging I can watch the tach literally moving up and down not in sound.
    I have owned a few different motor configurations Harleys, but that’s not what I’m talking about. I wish it wasn’t so hard for me to post a video so you could see the tac fluctuate
    Thank you
  19. #37
    Oct 2019
    La Porte
    Thanks Jack, I’ll be sure to check.
  20. #38
    100+ Posts
    Sep 2018
    Martinez, CA, USA
    There is a metal purge tube on the top of the throttle body. It should have a rubber cap on it. Maybe it was damaged or knocked off during the air cleaner change. This will act like an intake leak.
  21. #39
    #4 in this diagram
  22. #40
    On my 2019 …It reads 950 plus or minus -50 rpm’s… so knowing how questionable the accuracy of Harleys gauges are a thousand RPMs plus or minus being seen would be normal… I think we’re getting into beating a dead horse territory now..
  1. Replies: 6
    Last Post: 01-14-2017, 02:31 AM
  2. Replies: 4
    Last Post: 05-13-2014, 04:48 PM
  3. S&S air cleaner?
    By Dante221 in forum Harley Trike Conversions
    Last Post: 05-22-2011, 10:14 AM
  4. Air cleaner and tube vibration
    By Big Dog in forum Stallion Trikes
    Last Post: 10-11-2010, 07:35 PM
  5. SE air cleaner
    By Ironhorsepilot in forum Harley Trike Conversions
    Last Post: 10-07-2010, 03:35 PM
