BigN693GorillaEnabled TrikersFull length floorboards
Likes Likes:  15
Thanks Thanks:  7
Results 1 to 18 of 18
Thread: Need Help
    5+ Posts
    Apr 2023
    Massapequa NY USA
    Default Need Help
    I am a auto transmission technician not a motorcycle tech that being said I took the cover off my trike it was in my garage all winter on a trickle charger “ harley “ and turned the ign switch on all my drive lights came on and the fuel pump BUT no radio,gauges handle bar controls , odometer or security light and of course no power to starter switch ? I checked ALL fuses load tested battery changed batteries in key fob ? I’m lost
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    How did you load test the battery?
    How much did the battery drop in volts when you load tested it?
    Stupid question, did you have the run switch on when you tried to start it?
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    I think you need to get a new battery, Especially if its the original battery from 2018..
    Also you say trickle charger.....If by that you mean its not a battery maintainer and one of those half amp contestant charger that type can rune a battery if left on all winter..
    2019 Tri-Glide.......
    5+ Posts
    Apr 2023
    Massapequa NY USA
    How did you load test the battery? Snap on load tester
    How much did the battery drop in volts when you load tested it? 1.5
    yes
    5+ Posts
    Apr 2023
    Massapequa NY USA
    ‘sorry it is a battery tender bought from Harley Davidson
  6. DKCustoms postbit
  7. #6
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Quote Originally Posted by Rick Sinacore View Post
    Another thought…..when you press the start button are you pressing the brake pedal “hard”…?…..if by chance if the trike is in gear it ‘ by design won’t start …Again if the original battery is in the Trike’ I would get a new replacement….
  8. #7
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Default Just a suggestion
    Try a jump pac , then the on off ign switch procedure to reset the computer.
  9. #8
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    You said you checked fuses, did you probe both sides of ALL fuses with a test light?
    Check the battery cable lug on the starter for voltage, you should see the same voltage as @ the battery
    Pull the main fuse ( 50 Amp) under LS cover, clean the spade ends and reinsert it, does the fuse wiggle?
  10. #9
    5+ Posts
    Apr 2023
    Massapequa NY USA
    READ READ THIS IS MY STORY AND FIX !!!!!!
    READ READ READ !
    So I took the cover off of my 2018 triglide that I bought new turned the key on and no start, after I also noticed no radio and no handlebar controls no odometer all external lights and fuel pump comes on! So I changed fob batteries I checked fuses I load tested battery I checked all connections and found nothing.
    People telling me must be BCM so I decided to bring back to dealer. After many days they tell me BCM was fried gave me a price 900.00 with labor lol it takes 30 seconds to change, anyway then they call me back to tell me the part is obsolete and the new one is 180.00 more bringing the bill past 1000.00 and tell me that’s were we have to start !
    I wasn’t happy so I started looking on u tube and found a story of this guy who had a similar problem he said some bikes when put together at factory or when someone changes handlebar they pinch the harness coming out of left control. So I decided to pick bike up pay them the 150 diagnostic fee I bought it home turned key on and started to loosen the bolts on left controls and almost everything went on.
    So I took off the rest of it and found this I fixed the wires and now the bike is fixed I called Harley and told service manager to listen to this and I started bike ! Then went down to Harley and bought new harness 25.00 and bike is now completely fixed ! So just wanted to share my experience if this happens to you ck these wires.
  11. #10
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    READ READ READ ! So I took the cover off of my 2018 triglide that I bought new turned the key on and no start, after I also noticed no radio and no handlebar controls no odometer all external lights and fuel pump comes on! So I changed fob batteries I checked fuses I load tested battery I checked all connections and found nothing. People telling me must be BCM so I decided to bring back to dealer 🤮after many days they tell me BCM was fried gave me a price 900.00 with labor lol it takes 30 seconds to change, anyway then they call me back to tell me the part is obsolete and the new one is 180.00 more bringing the bill past 1000.00 and tell me that’s were we have to start ! I wasn’t happy so I started looking on u tube and found a story of this guy who had a similar problem he said some bikes when put together at factory or when someone changes handlebar they pinch the harness coming out of left control. So I decided to pick bike up pay them the 150 diagnostic fee I bought it home turned key on and started to loosen the bolts on left controls and almost everything went on so I took off the rest of it and found this I fixed the wires and now the bike is fixed I called Harley and told service manager to listen to this and I started bike ! Then went down to Harley and bought new harness 25.00 and bike is now completely fixed ! So just wanted to share my experience if this happens to you ck these wires
  12. #11
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    So, were the wires pinched from the factory the entire time and just now reared its ugly head? Or had you before you parked it for the winter nap done any work on the controls or handle bars?
  13. #12
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    Glad to see a possible nightmare work out for the better. Also thanks for giving a fix to your issue, so many will post about a issue then go dark. So no one knows the fix.
  14. #13
    30+ Posts
    Apr 2023
    SHEBOYGAN
  15. #14
    1+ Posts
    Aug 2020
    Star, city ,Indiana ,us
    Default Mouse
    My problem was from a mouse spending the winter in my fairing. Electrical tape fixed everything.
  16. #15
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Quote Originally Posted by Reddragon63 View Post
    Moth balls…When I would put my snowmobiles away in my pole barn I would put moth balls around the machines .. That solved z The mice problem..
  17. DKCustoms postbit
  18. #16
    150+ Posts
    Apr 2022
    Pipe Creek, TX, USA
    Cool
    yes, but wasn’t tough on the Moths?
  19. #17
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Quote Originally Posted by Olddog View Post
    Once the moths balls were removed they couldn’t reproduce….👍..
  20. #18
    20+ Posts maniacmac's Avatar
    Mar 2022
    Prescott
    Check the system relay they are known to corrode at the spades. If you need one go to your local autoparts store they have them stock for 1/3 of HD price
  1. Need major work and need recommendations. WHO
    By guatdoc in forum Honda Trikes
    Last Post: 01-30-2017, 05:15 PM
  2. Need help
    By redneckray in forum General Discussion
    Last Post: 05-31-2010, 01:03 PM
  3. Need Help
    By joelin5386 in forum Harley Trike Conversions
    Last Post: 05-29-2010, 06:00 AM
  4. Need some help with exhaust
    By johnchaparteguy in forum General Discussion
    Last Post: 03-18-2010, 12:38 PM
  5. Need your help
    By Terry Baker in forum General Discussion
    Last Post: 08-14-2009, 09:09 PM
