Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  2
Results 1 to 18 of 18
Thread: Vent on primary
    10+ Posts
    Jul 2017
    Shannon IL USA
    Default Vent on primary
    I just put the vent on my 2017 Tri Glide primary. Did anyone take that piece off the transmission?
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by Billr13 View Post
    What does that piece mean/is..??
    2019 Tri-Glide.......
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    If you are talking about the plastic retainer on the pushrod, yes remove it
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    If you bought your M8 new and did not have your dealer install the plastic button there will be nothing more to do than your install of the primary vent
    10+ Posts
    Jul 2017
    Shannon IL USA
    [QUOTE=Jack Klarich;926168]If you bought your M8 new and did not have your dealer install the plastic button there will be nothing more to do than your install of the primary vent[/Q
  6. DKCustoms postbit
  7. #6
    10+ Posts
    Jul 2017
    Shannon IL USA
    I did buy it new. I installed the vent and the instructions say remove the oil deflector if present. I could not find it in the parts manual. And I would have to take the exhaust off to get at it.
    So is that something the dealer would of put on?
    Thank You
  8. #7
    100+ Posts
    Sep 2018
    Martinez, CA, USA
    Right. My 2017 did not have the button. I changed out my slave so I was sure it didn’t have it.
  9. #8
    100+ Posts
    Sep 2018
    Martinez, CA, USA
    Thank You
    The dealer would only put it on if you were having fluid transfer problems. It was Harley’s first attempt at a fix. If you haven’t changed you clutch fluid you might want to have a look and do the fluid. It should be done every 2 years.
    You can get the cover off by just loosening the exhaust. When you have it off trim the bottom of it. Next time it will come off with only moving the heat shield. The trimmed part doesn’t show.
  10. #9
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Quote Originally Posted by PanheadSteve View Post
    Just a side note.....The dealer with Harleys OK put the button in my 2017....To stop the oil migration .....It made it worst....The migration went from around 15 hundred miles down to 8 hundred or less to a dry transmission....And at that early stage the vent' For lack of a better word wasn't invented yet......
  11. #10
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Thank You
    Did you have your dealer look @ your trike for the transfer problem?
    They may have put it on via HD warranty it to your dealer but I would think they would have told you they were doing it
    You can take your slave cylinder off and look in the hole to see if it is there, it will look like this
  12. #11
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Thank You
    Before you go taking anything apart.......Have your dealer run your VIN Numbers and if Harley, Or Any Harley Dealer had installed it it will come up on their computer...
  13. #12
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Would it not just be simple enough to check with his dealer, or look @ all of his service records, it should be there if he ever had it to the dealer for the transfer problem
    I think we are over thinking this JMO
  14. #13
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    It would take less than 10 minuets for the dealer to run the VIN...Its like a DNA...
    When i bought my 2019 Triglide used with under 2 hundred miles on it I had a dealer (not the one i got it from) run the numbers, And he had a print out with everything that was done and at what dealer did the work....
  15. #14
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    I still say either the dealer put it on or not, there is a paper trail @ the dealer
    Bill should know if the deflector was installed and should have paperwork that supports that
    KISS always works for me
  16. #15
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    The paper trail is the VIN Number print out....
  17. DKCustoms postbit
  18. #16
    18000+ Posts
    Tech Contributor
    Oct 2016
    Jax, Fla USA
    Bob, either Bill knows or not and has a receipt ( work order) from a dealer doing the job
    Have you ever had a bike serviced at a dealer and not got a copy of the work order?
    Why are we beating ourselves up over this any way?
    Show us the work order and be done with it, forget chasing the VIN and wasting time, either it was worked on or not
  19. #17
    1000+ Posts
    Aug 2016
    Des Moines IA US
    I trimmed the bottom of my cover and I don't have to move the heat shield or anything else, just loosen the 2 bolts and it comes off just fine, didn't want to go thru all the trouble of loosening everything up the next time so I trimmed it down, and it doesn't show from the side or top, never did look at the bottom, LOL
    All for now Trampas
  20. #18
    100+ Posts
    Jun 2022
    South Carolina
    The bike is probably due to have the brake cylinder fluid replaced at this point anyway.
    Simply remove the secondary cylinder and look.
    If the baffle is there, remove the cover (nothing will fall out), and remove it.
    Name:  9 Remove Cylinder.jpg
Size:  110.9 KBName:  10 Oil DeflectorAA.jpg
Size:  42.4 KBName:  11 Oil DeflectorAA.jpg
Size:  42.0 KBName:  12 Oil DeflectorAA.jpg
    US Navy Veteran
    Airframe and Powerplant Mechanic 43 years
    1989 FLSTC
    2019 FLHT
    2022 Tri Glide
  1. Primary Vent
    By andyjr11 in forum Harley Tri Glide
    Last Post: 08-18-2019, 04:24 PM
  2. Rearend vent
    By Wayne Harmsen in forum Honda Trikes
    Last Post: 01-13-2013, 09:17 AM
  3. Dash Vent on Stallion
    By casroy in forum Stallion Trikes
    Last Post: 01-11-2012, 08:57 PM
  4. Windshield Vent Install
    By 93TrikeWinger in forum Accessories
    Last Post: 05-08-2011, 02:44 PM
