14TG3Jack KlarichHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
14TG314TGHarley Tri GlideInstallation of a new Fuel Filter &...
Likes Likes:  14
Thanks Thanks:  5
Results 1 to 20 of 26
Thread: Fueling Short Sump Plug
    100+ Posts OLBLU's Avatar
    Apr 2018
    Winnipeg
    Default Fueling Short Sump Plug
    Just ordered a Feuling short sump plug and I am unsure where to install it on a 2017 107 CI M8 trike. Does anyone know if it is the same location as a 2019 trike?
    Or if anyone has already done it , can you please send pictures of the location. Also is the factory plug red in color?
    Sorry if I seem stupid , but the picture in the factory owners manual of the engine and trans drain plugs has me confused. I keep wondering if the sump plug is plug #3 , the one the manual says not to remove.
    Thanks in advance.
    It is NOT the plug in the oil pan, it is in the crankcase
    Look under the RS of engine, # 23 in diagram
    Apr 2018
    Winnipeg
    Thank you Jack. Now I feel like a complete idiot. I should have figured the difference between the engine case and the oil pan.
    Now the fun is going to be lying on the ground trying to get at the plug.
    Quote Originally Posted by OLBLU View Post
    You may want to use a heat gun to help get that plug out, go slow removing it, if it does not go easy use more heat, that plug could crack the case coming out
    Same going back in, it does not have to be super tight to seal
    Good Luck on your project
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Thanks in advance.
    Excuse my ignorance but why you change a sump plug?
    Quote Originally Posted by nucseal View Post
    On the M8 engines the sump plug interferes with an oil return passage in the crankcase
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Pat, here's a short video from last year.
    https://www.triketalk.com/forum/thre...hort+sump+plug
    Someone can correct me if i'm wrong.....I think the reasoning is that the new plug is a little shorter so more oil can flow....?...(To stop sumping).
    Yes you are correct Bob, the M8 crancases are different than the Twin Cams
    Thru the manufacturing process on the M8 crankcases not ALL of the M8 cases are the same
    Some of the cases the sump plug is set deeper causing an obstruction to an oil return, gallery. Note not ALL cases are the same, see this thread for more info
    https://www.triketalk.com/forum/thre...mping?p=900001
  11. #10
    go slow removing it, that plug could crack the case coming ouT....Same going back in, it does not have to be super tight to seal
    So the caveman approach ....Tighten till it strips then backoff a 1/4 turn does not apply here.....
  12. #11
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Thanks Jack and Gary for the info. With my luck, I think I will leave it alone.
  13. #12
    Discretion is the Better part of Valor........AKA: If it ain't broke leave it be...
  14. #13
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    If it ain't broke don't fix it isn't in the Harley mantra. Fix it till it's broke is.
  15. #14
    Sometimes when not riding some will sit and stare at their bike and become bored so they feel the need to add something to their bike whether or not it’s necessary or practical…
    IE; Hey I’ve seen this Do-Dads on a Hardcore Harley Forum…And ask has anyone seen this..Then the next thing that happens is everyone is going to have to have it…. JC Whitney was the King of Do-Dads …(Like put a Special Whitney golf ball in your gas tank and you’ll get 87 MPG.😁…1
  16. #15
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    My brothers and I ordered a lot of stuff from J.C.Whitney. I ordered those tablets that you drop in the tank to increase fuel mileage for the winter rat I had. Don't think they worked. That car always had a bad smell when the heater was running. I found out from a local old time cop that a mobster had be found shot in the head in that car down by the canal. It was summer and he was in there for about a month till someone got suspicious. Sold that car in the spring.
  17. DKCustoms postbit
  18. #16
    100+ Posts
    Jun 2022
    South Carolina
    I have split M8 crankcases and seen the OEM plug, in my opinion the short plug is a cure for a non-problem, invented by a company that wants to sell overpriced plugs.
    If you are really concerned that your engine will sump, install the latest design OEM oil pump, about 150 dollars.
    Your factory service manual will walk you through the entire job start to finish.
    US Navy Veteran
    Airframe and Powerplant Mechanic 43 years
    1989 FLSTC
    2019 FLHT
    2022 Tri Glide
  19. #17
    80+ Posts Jd1a's Avatar
    Oct 2018
    Waddell, AZ USA
    Looked at this video from DK.
  20. #18
    Quote Originally Posted by Dan SC View Post
    The M-EIGHT main sump cross port on the inside of the M-Eight engine case is in a slightly different location & height in each engine case. This cross port is created when the bottom plug hole is machined and tapped by the factory. The machining breaks through the casting wall, creating the sump port. Whereas the Twin Cam engine cross scavenge pick up hole is a machined bore, and is in the same location in every engine case.
    Not every M8 crankcase is the same, that said even some M8 engines with the new oil pump ( introduced in 2019 and is the current pump thru 23 models) have shown signs of sumping
    It would make sense on 17 - early 19 models to install the newer oil pump first, still if IMO it were my engine I would install the shortie sump plug @ the same time
    JMO
  21. #19
    Apr 2018
    Winnipeg
    Finally installed the Feuling shorty sump plug today. ( Mail to Canada take forever these days.)
    Took it slow. Preheated motor and then put a heat gun on sump plug for 5 minutes. No problem with removal.
    Even though my engine was good with only 6 ounces in the sump, I am glad I installed the new plug as a piece of mind thing.
  22. #20
    70+ Posts
    Oct 2014
    kearney mo.
    Default sump plug
    Checked the amount of oil in my 2019 trike there was 8 to nine ounces of oil supposed to be no more than six, put new plug in and had harley replace the oil pump, lifters, adjustable push rods. about 1900. dollars. Removing the sump plug was no problem. It might be a little over board for some people but it runs a lot better now and a new engine would be about 8000.00 dollars
  1. Feuling Oil Pumps - Cam Plates - & More!
    By DK Custom Products in forum DK Custom Products
    Last Post: 05-22-2023, 11:40 AM
  2. what do you consider short short ride or The Long Ride ?
    By Hank62 in forum Harley Trike Conversions
    Last Post: 07-21-2017, 12:22 PM
  3. carbon in sump
    By matman1972 in forum VW Powered Trikes
    Last Post: 04-16-2015, 11:29 AM
  4. Finally installed the 1.5 quart oil sump
    By pmascarenas in forum VW Powered Trikes
    Last Post: 05-04-2013, 10:57 AM
  5. Change 5-round plug-in to 4-flat plug in for trailer
    By BinIdaho in forum Harley Trike Conversions
    Last Post: 02-26-2013, 11:42 PM
