Likes Likes:  2
Thanks Thanks:  3
Results 1 to 8 of 8
Thread: tire change problem
    30+ Posts
    May 2010
    Hoschton, GA
    Default tire change problem
    I put on a new front tire. When I was done on the test drive the transmission started shifting strangely the HSA blinked amber. the Torque Control was blinking and the ABS blinked, drive indicatour and the Tour blink and show as asterisk and I could not accelerate above 40. What can be wrong? Need help when i would let off and then try to speed back up it would work for a while then the Torque control light would come back on and begin to slow down again.
    Has anyone had this problem??
    Quote Originally Posted by marshall View Post
    I have to ask....Did you put back the same exact size tire..?
    1000+ Posts
    nucseal's Avatar
    Jan 2012
    San Antonio, Texas
    Possible the rim is on backwards. The pickup bearing for ABS is on the wrong side. If I remember correctly ABS sensor and ABS Bearing is on left side of wheel. Just my thoughts, something to check!
    30+ Posts
    May 2010
    Hoschton, GA
    No. I put a rear tire as I have for years on my older Goldwings.
    So you put a different tire on that was the one you had on Before the problem started..Could be that’s the problem?
    800+ Posts woody's Avatar
    Jul 2012
    Talladega,Al 35160
    Quote Originally Posted by nucseal View Post
    This sounds like your problem and if so tire may have been mounted backwards.
    2019 Goldwing CSC
    30+ Posts
    May 2010
    Hoschton, GA
    Default Fixed and working great again.
    I found that I had tightened the pinch bolts before the axel was completely seated.
    reseated the axel torqued it correctly and then tightened the pinch bolts, problem solved.
    the axel was only off by les than a 16” but what a difference. Thanks to everyone for all the help.
    Marshall
    2500+ Posts
    cScjhb's Avatar
    May 2020
    Mesa, Arid-Zone-A
    Thanks for the follow-up. Glad you got it sorted out. Another bit of information that may help others in the future.
    2014 CanAm Spyder RTL SOLD
    Semper Fi
  1. Replies: 1
    Last Post: 05-07-2018, 07:10 AM
  2. Oil Change using a Flo and Go Vacuum Oil Change Kit
    By daf62757 in forum Harley Tri Glide
    Last Post: 03-17-2017, 06:14 PM
  3. Spedometer Problem & Emergency Brake Problem
    By JohnT1949 in forum Harley Freewheeler / Road Glide 3
    Last Post: 08-20-2016, 12:29 PM
  4. Can somone calculate tire size change?
    By mcdonaldroadcapt in forum Harley Trike Conversions
    Last Post: 06-11-2014, 06:48 PM
  5. Small jack for rear tire change
    By kmawing in forum Tires, Wheels, Brakes, Front End
    Last Post: 08-21-2013, 05:58 AM
