Most ride with 38 - 40lbs for front tire. I use 40lbs in my front tire cold.
You can go as low as 22lbs in the rear for a soft ride. The tires are not supporting nearly the weight the tires were design for. At lot least weight on a trike, that is why you can go to a lower tire pressure.
