Likes Likes:  16
Thanks Thanks:  3
Results 1 to 13 of 13
Thread: 2014 HD Tri-Glide Rear Brake Rotor/Brake Pad Replacement Video
    90+ Posts
    Jun 2018
    Forney, Texas, USA
    Default 2014 HD Tri-Glide Rear Brake Rotor/Brake Pad Replacement Video
    I am going to replace the rear brake pads on my 2014 Tri-Glide and am thinking about replacing the rear rotors, as well, since the left rear rotor has a small circular groove cut into the rotor. In turn, is anybody aware of an internet video displaying the "step-by-step" process of changing the 2014+ Tri-Glides' rear brake pads and rotors? I have searched "You Tube"; however, the videos, I have found, are for the earlier year Tri-Glides. I have the 2014 Trike Supplement Service manual; however, an instructional video always seems to provide more information, detail, and service tips.
    Thank you,
    Allen S.
    90+ Posts
    Oct 2015
    Indianapolis
    I have from time to time searched for the same video, but to date, nothing has been found.
    Quote Originally Posted by keikat2 View Post
    Thank you,
    Allen S.
    I believe on the 14 model, slacken the E brake, then you can compress the caliper piston
    Before you do this, remove most of the fluid from the master cylinder, as you compress the pistons of the calipers it will raise the master cylinder level
    Wash your rotors in soapy water and rinse with ample water , blow dry them with compressed air
    install the new pads, attach caliper and bleed rear brakes re adjust parking brake, confirm a full pedal, go for a test ride
    If your caliper pistons have 2 holes, you will need to rotate the pistons while pushing in at the same time, I hope this helps
    90+ Posts
    Jun 2018
    Forney, Texas, USA
    Thank you "daf62757" and "Jack" for your responses. I installed the front brake pads on my Trike yesterday. With the help of the 2014 Tri-Glide Service Supplement manual and Jack's detailed explanation hopefully I can figure it out. I have certainly come to rely on the You Tube videos when performing maintenance on my Trike.
    One question Jack. If I remove some of the brake fluid from the Rear Master Cylinder Reservoir and leave just enough to entirely cover the bottom of the reservoir, will the rear brakes need to be bled?
    Best of Luck,
    Allen S.
    Best of Luck,
    Allen S.
    Bleeding new fluid thru the system is always a win win, it removes the moisture and gasses that build up, equals better braking and less brake fade
    650+ Posts Notgrownup's Avatar
    Oct 2021
    Snow Hill NC USA
    Make sure you leave the e brakes off Jack the bike , removing the calipers is not complicated, simple tool. Leave the old pads in and spread them a little bit with a flathead screwdriver…if you want better stopping power get double sintered pads like EBC HH. If you’ve ever changed pads & rotors on a car, it’s not that much different.
    Be who your dog thinks you are.
    2021 Tri Glide Ultra Vivid Black with some Farkles.
    80+ Posts
    Dec 2023
    New Castle, PA, USA
    Just saw this thread and going to post a video that I did a few months back on changing out brake pads on my 2014 Tri Glide.
    Note: These are pretty easy to do, but “un adjusting” the E-brake cable is required…. Then once the brake job is complete, you need to “re adjust” the E-brake cable. Again, it’s easy to do & hope this video helps.
    I believe this will only apply to 2014-2018 year trikes.
    YouTube video link:
    https://youtu.be/fKy6ONKj1cs?si=jNgHCHMPxja3yRLn
    150+ Posts David792's Avatar
    Mar 2019
    Idaho Falls, Idaho, United States
    Quote Originally Posted by 14TG View Post
    YouTube video link:
    That is actually a pretty good video despite being shot on a cell phone. He covers stuff you might not see elsewhere such as cleaning and lubricating the caliper guide pins.
    2018 Tri Glide Ultra Classic. Vivid Black.
    Jan 2022
    Las Vegas
    Default I made it simple
    Thank you,
    Allen S.
    So this is not for everyone. I removed everything to do with the e brake on my 2012 Trike. It has made changing pads and rotors so much easier. Have ridden a 2-wheeler for over 55 years before transitioning to 3, I never had a need for an e brake. I never used the e brake for the first 10 years of riding the Trike either, so removing it was not a problem for me. Just my 2 cents.
  11. #10
    Mar 2019
    Quote Originally Posted by Nevtat1450 View Post
    Wow! That's quite an event. I get the point, but... I use the parking brake when I'm stopped and just need to keep it from rolling a little. Usually when I'm at home in the garage or at a quick stop. If parked at a motel or just a gas stop I leave it in gear. I'll see your 2 cents and add my 2 cents.
  12. #11
    Oct 2021
    Snow Hill NC USA
    I use my E brake all the time and I like to have it working properly and adjusted perfectly. Changing the rear pads was no more complicated than working on a car brakes
  13. #12
    80+ Posts
    Dec 2023
    New Castle, PA, USA
    Quote Originally Posted by Notgrownup View Post
    100% agreed…
    These trikes weigh a few hundred pounds more than a 2 wheeled touring bike.
    The rear brakes (the front, as well) are indeed very easy to do. And although it may look intimidating to some, the process is pretty easy. The shop manual is spot on, but the video also will help with a visual.
    Adjusting the Parking brake is also very simple to do. For the few months that I have owned mine since September, I think the only time I didn’t use it is when it was sitting on a level and fueling up. Otherwise, I used it all of the time.
  14. #13
    750+ Posts
    JTJersey's Avatar
    Jul 2021
    Millville NJ USA
    There's a thread on the site where I was going to pull my emergency brake off my '21 Freewheeler. Mostly because I don't like how it looks. Had it all figured out, but in the interim period I found myself using that brake more and more. Now I take it for granted when I'm parked on anything except level ground and even then, depending on where I'm at, I'll put it on as an extra security measure.
  1. Brake rotor replacement
    By freedomrunner in forum Motor Trike
    Last Post: 09-27-2021, 06:13 PM
  2. Video - FAILED 2019 Tri Glide Battery Replacement
    By DK Custom Products in forum DK Custom Products
    Last Post: 02-18-2021, 05:55 PM
  3. Disc Brake pad replacement
    By durango9 in forum Honda Trikes
    Last Post: 11-27-2017, 08:04 AM
  4. Rear brake rotor
    By GARYD in forum Harley Trike Conversions
    Last Post: 10-16-2012, 06:48 PM
  5. Front Brake Pad Replacement
    By Gorilla in forum Stallion Trikes
    Last Post: 07-11-2011, 11:07 PM
