BigN693GorillaEnabled TrikersFull length floorboards
Likes Likes:  3
Thanks Thanks:  1
Results 1 to 20 of 20
Thread: 2013 Victory Vision Crossbow frame weld cracked
    5+ Posts
    Dec 2020
    Philadelphia, PA USA
    Default 2013 Victory Vision Crossbow frame weld cracked
    Hit a speed bump and right side of trike collapsed into wheel well due to weld breaking at right side crossmember to wheel arm and broke belt in the process of getting it off the road. Now I have a broken obsolete trike that I can't seem to find parts for ( trike kit parts) and nobody wants to touch it (as far as welding) due to liability issues. Coming here to get some ideas and suggestions as I am at a loss as what to do. It was fully covered and insurance company adjuster wrote an $1200. estimate which I didn't accept due to reasons above... Help! 🙃
    2013 Victory Vision Tour Crossbow Trike in Black, Miller Mufflers, Trailer Hitch w/ Bushtec lock pin.
    ********* No Good Deed Goes Unpunished *********
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    Quote Originally Posted by Cruiser5406 View Post
    Try this - since the adjuster wrote a $1200 estimate, he must have gotten that figure from somewhere? Perhaps he can provide his supplier's contact info and they can fix it. If not, then maybe they will total it.
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Have you tried talking with the shop that installed the trike kit….I see you’re from Philly… hopefully it wasn’t from new Berlin New Jersey..I think they close shop..?
    2019 Tri-Glide.......
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    First thing to find out, if you keep it and have it welded does it need to be certified by your state?
    Contributing Member ROAD DOG's Avatar
    Jan 2009
    MA,
    Is it steel or aluminum? The insurance adjuster more than likely pulled that number out of his Ass ! he has no books or anything to go by on the parts time or labor. Can you post a picture ? Find a good Welder have them weld it up & reinforce it , if the weld broke it can be rewelded & made better than new . I dont see a big deal .
  6. #6
    100+ Posts
    Feb 2017
    DE
    Street rod frame builder, would be your best bet, send pics, or talk to s&w in spring city pa.
  7. #7
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Quote Originally Posted by ROAD DOG View Post
    Is it steel or aluminum? .
    The victory, crossbow bikes are aluminum frame..
  8. #8
    100+ Posts
    Feb 2017
    DE
    Also, a big warning out, to all the others to check your frames. Victory or otherwise with same kit
  9. #9
    5+ Posts
    Dec 2020
    The part that is cracked would be like a sub frame for the trike part only. It connects the bike to the trike part. It is steel. I will try to post pic as it has part # or serial number on it.
  10. #10
    5+ Posts
    Dec 2020
    This is the factory Crossbow kit that was installed only in Spearfish, SD by Lehman. The Vision is Aluminum frame bike however the trike kit and most parts are steel.
  11. #11
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Who made/ manufactured the Trike part …And did you install it yourself?..Or did you have it done by a shop?
  12. #12
    100+ Posts
    Feb 2017
    DE
    Tried to dm you, is part removable, ect. Try n message me.
  13. #13
    5250+ Posts Pegasus1300's Avatar
    Oct 2011
    Spring City,Utah, USA
    Find a fabricator or frame builder there in the Northeast. See if he will build you some fish plates to connect the trike (steel)to the Victory frame (aluminium ) without welding. Do both sides. You will probably have to travel a bit. I am assuming you have tried to contact the old Lehman shop or their successors, if any? I thought one of the major trike companies took on the shop.
    Happy TRAils/NSD
    Paul
  14. #14
    5+ Posts
    Dec 2020
    This was / is a Factory (Lehman) made Crossbow trike kit installed at Lehman facility in Spearfish , SD . I bought it used already built in 2018 on consignment for $20K at the original shop that sent this bike to be built into trike back in 2013. I believe the axle is made by Champion? The rest of trike kit was made and built exclusively by Lehman. This is best info I have learned but all parties involved seem to be no longer in business.
  15. #15
    5+ Posts
    Dec 2020
    Quote Originally Posted by TwistedKarma View Post
    I am going to try to disassemble the trike and remove that part and see if it can be fixed or maybe fabricate a new one but seriously, I would love to find a way to put an Independent suspension on this trike as the ride is awesome on nice roads but where I live in Phila, PA , it's annoying and painful. It's called live and learn I guess. I just want to ride the damn thing and I have the worse luck with decision making and choices I usually regret. Still Victory is my favorite and zero regrets on the bike part ever!
  16. #16
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Victory a.k.a. Polaris made a great bike. I had one of the iron frame ones the gunner’ but as soon as Polaris pulled the plug on Victory, I traded it in for another triglide…
  17. #17
    850+ Posts Rmitchell55's Avatar
    Dec 2012
    Santee
    Lehman trikes was bought out by Champion when John Lehman died, the Champion was bought by D & D Cycles in Mesa, AZ. ?? I don't know if Champion of AZ. still has parts for Lehman.
    Ray
    2017 Harley Triglide
    Tijuana Border
  18. #18
    5+ Posts
    Jan 2019
    Lenexa, ks
    This happened to my 2011 Vision trike. The original owner was a millwright. I believe he took off the fenders and found the broken welds. He then made some gussets or brackets and welded them where the were cracked or broken making them stronger then they were. My question is now how to lift up the trike to inspect the under carriage that he welded. Any help there??
  19. #19
    100+ Posts
    Feb 2017
    DE
    Ramps for a car? 2x8. With bracing slower incline, could that help?
  20. #20
    30+ Posts
    Mar 2023
    Bellmawr
    The Trike Shop that was in Berlin, NJ (Ace Trike) moved to Glassboro for a few years. As of last October they moved again, this time to Harrington, DE.
  1. Replies: 3
    Last Post: 07-25-2021, 06:35 AM
  2. NEED HELP!... What Angle to Weld New Neck Tube onto my Frame????
    By inkslingersourwine in forum VW Powered Trikes
    Last Post: 02-18-2017, 06:40 PM
  3. Lehman Trikes CrossBow now available for 2014 Victory Vision!
    By Trike Talk News in forum Victory Trikes
    Last Post: 05-21-2014, 02:55 PM
Tags for this Thread
