LD-Ordie1LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  1
Results 1 to 8 of 8
Thread: Fuel guage always reads full
    750+ Posts
    May 2011
    peru,in,usa
    Default Fuel guage always reads full
    1999SE. GL1500 goldwing with roadsmith kit, with aux tank.aux tank fuel transfer doesn't work. . Does the aux switch position transfer fuel to main tank when the low fuel light comes on OR does it feel the engine? Is there a easy fix?
    I'm going to replace the fuel pump assembly, as I have a new one .pictures later
  2. Roadsmith banner
  3. #2
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Quote Originally Posted by eagle1 View Post
    Yes, it transfers fuel from the aux tank to the Honda fuel tank. I've replaced a few over the years and it is an easy fix.
  4. #3
    750+ Posts
    May 2011
    peru,in,usa
  5. #4
    750+ Posts
    May 2011
    peru,in,usa
    Update. Remove right rear tire.
    Transfer valve not getting power, with selector switch in the down position
  6. #5
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    So did that fix it?
    750+ Posts
    May 2011
    peru,in,usa
    Yes it fixed the instrument fuel guage problem. Thanks again
    Sep 2016
    Springfield, Mass. USA
    WOW! you lucked out "big time"
    750+ Posts
    May 2011
    peru,in,usa
    Default '99 GL1500SE, with roadsmith kit. can't transfer fuel to main tank
    see jppeg. i believe this is thw wires going to the transfer switch. main tank is empty. with transfer switch is in the bottom position. but its not transfering fuel to main tank. i don't see a low fuel light on the dash. how do i make this a transfer fuel, when i manually select the lower position on the switch. thanks. lb
  10. Roadsmith banner
  1. erratic guage
    By miabobo in forum Honda Trikes
    Last Post: 04-22-2019, 12:18 PM
  2. Oil level reads high on LCD Dipstick
    By DaveHigdon in forum Harley Tri Glide
    Last Post: 10-22-2014, 02:58 PM
  3. Fuel guage
    By Lakeman in forum Harley Trike Conversions
    Last Post: 06-18-2012, 08:59 AM
