Likes Likes:  11
Thanks Thanks:  1
Results 1 to 10 of 10
Thread: ignition key
    Jul 2023
    Livingston
    Default ignition key
    this may have been discussed before but I only got one ign key for my bike[guess the original ignition switch had to be changed]. I marked the depth my ign key goes in and went to a local ace and with my trips back and forth he ended up making a key 4 different times from different blanks[3 with their auto machine and one with the old machine],none worked.They seem to go in deep enough but do not turn the switch on.I went to a ace store 30 miles away and they told me they did not even have a correct blank to cut!This is a 2014 GL1800 , when I had my 2002 GL 1800 ace cut several ign keys with no issue.Any suggestions? Do I order a blank like from ebay or amazon?
    Quote Originally Posted by trikeguy74 View Post
    Get a blank from a Honda dealer…. And then have it cut by a shop that specialize in key cutting and locksmithing..I did that years back with my VTX 1800 Bike…
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    First is the need to have a real locksmith, of lock shop to cut your key blank. I beleive there are a couple of known, generic key blanks that others uses. Here we stock OEM blanks, and if one is needed, we would only use a lock smith to cut it.
    Part #5 in the fishe below.
    https://www.mrcycles.com/oemparts/a/...bar-top-bridge
    350+ Posts pwhoever's Avatar
    Jul 2016
    Southeastern Wisconsin
    Not sure what the difference is but for your 2014, they list a different part # for the key than the 2001-2010 use. Partzilla shows that the 2014 key can be used from 2012-2017. But Cyclemax shows different key part for 2012-2014 as well as 2017 and then another option for 2015-2016. Maybe it's just the design on the head???
    https://www.partzilla.com/product/ho...840f6568727012
    https://cyclemax.com/products/gl1800...41813639954612
    JustWings.com
    May 2016
    Quote Originally Posted by pwhoever View Post
    For 5th gens, to my knowledge, all key blanks are the same. The only differance is the shape of the head (black part) we turn with our fingers. The head also has an insert with a GW emblem, and sometime the emblem matches the color of the bike. All of those differances come with a different part number.
    30+ Posts Ramnight's Avatar
    Jan 2021
    Vicksburg, Michigan USA
    I have purchased the Axes 47 blanks on ebay and had them cut at my local hardware store.
    2012 With Champion IRS Kit, and new Wheels.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Quote Originally Posted by Ramnight View Post
    Are they OEM Jim? What are they costing on ebay?
    Sep 2016
    Springfield, Mass. USA
    Quote Originally Posted by GoldWingrGreg View Post
    Thank you Gregg!
    I like the idea of have a spear key with me 100% of the time...........I hide one on my TRIKE / so it's always with me
    4/12/24
    800+ Posts
    Nov 2021
    Lake Orion, MI, USA
    Thank you Gregg!
    4/12/24
    Thanks for letting us know where it is.
    Thumbs up This Thread
    I am watching this thread for more info
  1. removing ignition switch harley ultra classic
    By silverwing in forum Harley Trike Conversions
    Last Post: 06-29-2012, 04:05 PM
  2. Pre-ignition?????
    By CarsonTriGlide in forum Harley Trike Conversions
    Last Post: 05-20-2012, 03:14 AM
  3. Ignition issue
    By stockhatch in forum VW Powered Trikes
    Last Post: 04-05-2011, 12:18 PM
  4. Electric connection / Ignition on only.
    By rmrc51 in forum General Discussion
    Last Post: 03-09-2009, 06:06 AM
  5. Ignition switch question:
    By Fortsand in forum Stallion Trikes
    Last Post: 12-30-2008, 06:16 PM
