Likes Likes:  2
Results 1 to 7 of 7
Thread: Goldwing Roadsmith rear brake
    1+ Posts Grandpot's Avatar
    User ID
    34900
    Aug 2023
    Fort Mill, South Carolina
    Rep Power
    Default Goldwing Roadsmith rear brake
    I recently purchased a 2002 Goldwing with a Roadsmith conversion. I am the third owner so I don't have all the history. The Roadsmith conversion has an early serial number that places the Roadsmith near 2002.
    I need to press very hard on the brake pedal to get any real action. I mean REALLY HARD. I've looked at the calipers and pads, everything seems good. Before I start any deep troubleshooting, I would like to know if this is anywhere near normal for this vintage setup.
    What are your experiences?
    Regards,
    Keith
  2. Roadsmith banner
  3. #2
    250+ Posts
    User ID
    7209
    Jan 2012
    oz
    Rep Power
    300
    I'd call Road Smith and get a knowledgeable answer
  4. #3
    User ID
    9350
    Sep 2012
    Lakeland, FL
    Rep Power
    300
    I suggest the rotors may have become warped from overheating not apparent from just looking. Sad to say that is an expensive fix.
  5. #4
    User ID
    24367
    Rep Power
    300
    How does the brake fluid look?
    If it is old, there could be sludge in the cylinder, also plugging the port, this happens whit the age of fluid and gasses developing , this turns to water build up, then corrosive sludge
    Try removing as much old fluid as possible, then use Q tips or a clean rag to wipe the bottom of the master, have a close look for sludge
    Bleed the system with new fluid and give it a try
    Nuff Said," Were Burnin Daylight, Lets Ride"(Sober 36 years)
  6. #5
    User ID
    34900
    Aug 2023
    Rep Power
    Default Thanks
    Thank you gentlemen. I definitely will need to look deeper into this issue.
    20+ Posts
    User ID
    21736
    Feb 2016
    Newton Falls,Ohio,USA
    Rep Power
    298
    Default relink the rear brakes
    Roadsmith sell a kit to relink the rear brakes that were disabled with pre 2016 builds. I purchased a kit and installed it this year for mine.It has made a world of difference on mine the spongy petal is gone and the bike stops quickly now.
    User ID
    34900
    Aug 2023
    Rep Power
    Default Linked brakes
    John557, thank you. I did not know we could do that.
    Experience is recognizing the same mistake every time you make it!
  1. Replies: 2
    Last Post: 04-29-2023, 08:37 AM
  2. Replies: 7
    Last Post: 03-07-2023, 03:05 PM
  3. Replies: 40
    Last Post: 01-20-2020, 09:13 AM
  4. Roadsmith rear brake install
    By dmccord in forum Honda Trikes
    Last Post: 09-16-2018, 07:30 AM
  5. Replies: 7
    Last Post: 03-08-2016, 11:33 AM
Tags for this Thread
Bookmarks
