Likes Likes:  2
Results 1 to 6 of 6
Thread: Steering issue
    Sep 2023
    Pittsburgh, PA, USA
    Default Steering issue
    Hello all,
    Just went from a 2017 SGS to a 2023 Tri Glide. My suspension in the rear is at about 10. Psi in rear tires 22psi. Front tire I haven’t check recently. Anyways I have less than 400miles on the bike. But here is my question, while riding and going over bumps, my handle bars done have that smooth north and south movement, it’s more of a shaken east and west feeling. Any tips or advice?
    Quote Originally Posted by alexandersmjr View Post
    Hello all,
    Unless it’s severe ….I hate to say it but that’s relatively normal ..But check the air in your front tire I run 30 psi (19 Triglide)..it does make the steering a little heavier but it softens the ride over the bumps…
    400+ Posts
    Jan 2015
    Barrington, NH USA
    You can also get shake if the steering stem is not properly torqued.
    Sep 2023
    Pittsburgh, PA, USA
    Ok, I’ll double check the air pressure. If it continues, I’ll check the steering stem. Like I said first time on a trike didn’t know if it was normal, especially since the trike is brand new.
    30+ Posts
    Apr 2023
    SHEBOYGAN
    What about the steering dampener?
    If this is a new unit, take back to the dealer.
    Quote Originally Posted by DCR2013 View Post
    Sounds like a new trike…Only 4 hundred miles on it… quite often. Someone will buy a trike and because it’s three wheels they will think it will ride like a Cadillac. Also if they’re coming off a two wheeler, they might be trying to counter steer but you can’t do that on a Trike and you end up fighting the bars with a death grip on the handlebars…
    but yes, if he’s worried about it, he should take it to the dealer and let them test ride it .
  1. Tri-Glide Steering damper issue
    By rayg5102 in forum Harley Tri Glide
    Last Post: 11-04-2020, 10:08 PM
  2. Freewheeler Steering vs Tri Glide Steering
    By POPSHD in forum Harley Tri Glide
    Last Post: 01-08-2020, 09:45 AM
  3. Steering dampner
    By ROAD DOG in forum Harley Trike Conversions
    Last Post: 03-23-2009, 08:13 PM
  4. Steering Wobble
    By Pushrod in forum Harley Trike Conversions
    Last Post: 01-21-2009, 07:57 PM
