Likes Likes:  5
Results 1 to 11 of 11
Thread: Oil Change Without Lift
    Oct 2023
    Baltimore
    Default Oil Change Without Lift
    Good Morning to all,
    I am new to the Trike world. I need suggestions on changing the oil on my Roadsmith equipped Goldwing without a lift. Help please!
  2. Roadsmith banner
  3. #2
    350+ Posts Rogue1's Avatar
    Oct 2018
    Ramseur NC USA
    Quote Originally Posted by rjgreen3 View Post
    I don't ride a Gold Wing but is there any reason you can't change it with it on the floor?
  4. #3
    Sep 2016
    Springfield, Mass. USA
    I cut a 4X4 board three times at 14' long......................... I then jack up the rear of my TRIKE and place a 4x4 under each wheel, Then jack up the front wheel and place a 4x4 under the front wheel........ This raises up your bike 4inches , high enough to place a pan under the engine for oil changes...........
    Warning: BESURE TO PUT A TIE AROUND YOUR FRONT BRAKE TO HOLD YOUR BRAKE ON, AND PUT BIKE IN 1ST GEAR SO IT DOESN'T ROLL, WHILE YOUR UNDER THE BIKE
    I ride a Roadsmith trike also......... lift'n up the trike also allows me, to easily, wax my bike, or change spark plugs, and service it , as well.
    11/11/23
  5. #4
    800+ Posts woody's Avatar
    Jul 2012
    Talladega,Al 35160
    Before I got my 4 post lift I would run the back wheels up on my car ramps and then jack the front up level which gave me plenty of room work.
  6. #5
    80+ Posts
    Oct 2021
    Minnesota
    Home made stands work beautifully for all my Trike maintenance........
    These raise the Trike about 6" total.......
    Oct 2023
    Baltimore
    Quote Originally Posted by Rogue1 View Post
    Too low to the ground to get drain pan under the trike.
    250+ Posts
    Jan 2012
    oz
    I use a regular auto oil pan without a lift. No problem changing oil. simple to do
    30+ Posts Ghost Rider 2's Avatar
    Sep 2022
    Downs, Illinois USA
    I took a 4 foot 2 X 10 measure in from each end and cut a 45 degree cut 16" from each end. Lay each in front of each wheel. Pull trike up on boards. I have a small floor jack the ones you see advertised for $39 to $49. I have a small 4" x 4" thin piece of plywood I place on jack the roll it under engine case center. Lift trike up easy and drain. I also have a set of short filter pliers, easy to remove filter without having to remove lower cowel.
  10. Roadsmith banner
  11. #9
    20+ Posts Grandpot's Avatar
    Aug 2023
    Fort Mill, South Carolina
    Default Three ramps
    Ride it up on three ramps. Just be sure to stop at the top.
    Experience is recognizing the same mistake every time you make it!
  12. #10
    Quote Originally Posted by Grandpot View Post
    Real men don’t stop at the top…😁
  13. #11
    Real men don’t stop at the top…��
    Must be a quote from Evel Knievel
  1. Replies: 1
    Last Post: 05-07-2018, 07:10 AM
  2. Oil Change using a Flo and Go Vacuum Oil Change Kit
    By daf62757 in forum Harley Tri Glide
    Last Post: 03-17-2017, 06:14 PM
  3. Replies: 7
    Last Post: 07-08-2016, 03:45 PM
  4. Leaking oil after an oil change
    By trikerider55 in forum Harley Trike Conversions
    Last Post: 06-25-2012, 08:44 AM
  5. Oil-Oil-Oil
    By drumdoctor in forum VW Powered Trikes
    Last Post: 01-08-2012, 12:16 PM
