Likes Likes:  8
Thanks Thanks:  4
Results 1 to 9 of 9
Thread: Road Smith Trunk Leak
    250+ Posts rhino65's Avatar
    Aug 2016
    Atwood, Illinois United States
    Default Road Smith Trunk Leak
    Anyone have they're trunk leak right in front of bottom trunk hinges on their HTS 1800 conversion? Pretty sad a new conversion leaks. Tried adjusting top lock but no difference. Unable to post pics but laid paper towel all across bottom then sprayed with hose. Wonder if any other trike manufacturers have water leak problems on new kit. Pay way too much money to have 2 leaks
    2002 GL1800 with CSC trike kit
  2. Roadsmith banner
  3. #2
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Quote Originally Posted by rhino65 View Post
    Let me guess...was it converted in Alabama?
  4. #3
    Feb 2018
    Soddy-Daisy Tennessee USA
    Default Trunk Leak
    I purchased mine last year from K & D Cycle in Alabama. New 2023. I found the lower hatch bolts were not tighten and leaked. I siliconed them and that solved most of my problem. The trunk still leaks. I've seen on some threads that the rubber gasket could be installed incorrectly. I plan to contact them this year and ride down to have it repaired. Paid way too much to have this problem. Also, my tire pressure light on the dash never goes off. I've been told they do a short cut on the install to save $$'s. Ugh!!!
  5. #4
    Aug 2016
    Yes it was. Don't even get me started.
  6. #5
    Aug 2016
    Quote Originally Posted by gwright View Post
    I found several shortcuts they take. A front brake line not hooked up. Not sure how it links but I have front & rear brakes. Do not think they work together like they should. After getting my 08' GW with new conversion home last July I crawled underneath it & started looking around and adding accessories and now realize how they can crank out so many & be cheaper on prices. Not worth it
    Aug 2016
    Yes it was. Don't even get me started about other things I found after getting it home 560 miles later
    80+ Posts
    Feb 2014
    Toledo,Ohio-USA
    Default Trunk Leak
    Brethren,
    Not sure If You Tried This, But Check The Latching That May Need Adjusted Or The Next Thing Would Be The Hinge Adjustment. I w0uld Think The Weather Stripping Wuld Be OK
    Ayatollah
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Default The Proper Fix
    The leak is 100% due to the installer. I have corrected at least a dozen of these for RS owners who bought their trike or trike kit from a certain high volume discount dealer who promises a one same day installation. When Roadsmith builds the kit AND they paint it, they always correctly install the rubber trunk seal and it never leaks.
    This particular dealer always orders their kits unpainted, because they do their own paint jobs to save a few hundred dollars and promise a one day install. Who wants a one day install?? In their haste, very often the trunk seal is not installed properly and will always leak.
    The trick is to take a rubber or plastic dead blow hammer and starting at the top center of the trunk opening, gently, but firmly tap the rubber seal to seat it to the trike body's opening edge. The seal is a commonly used automotive u-shaped rubber tube that is molded to a tough plastic, metal impregnated flexible channel that seats over the fiberglass lip of the trunk opening.
    Starting at the top center and working to the left, firmly tap the seal every inch to seat it paying close attention in the top and bottom (4) radius of the opening as these are the areas that unless done exactly as I am describing, will not be fully seated and where leaks will occur. Make sure when you get to the lower radius, to hold firm pressure on the upper radius of each side as you tap in the seal at the lower radius so it does not pull away at the top.
    If it was installed incorrectly, when each side is reseated properly, you will see a 3/4" to 1" gap appear in the middle of the bottom of the seal's ends, due to the seal not having been seated all the way in the corners and thus being cut too short. The resulting gap on the bottom center of the seal can not leak, as water will not climb uphill and into the trunk. You can put a dab of clear silicone in the gap if you want.
    The leak occurs because water naturally enters the space between the body and trunk at the top of the body/trunk lid. This is a design element of all trike kit manufacturer's bodies. As water runs down the sides of the seal, it is wicked into the trunk due to a gap on one or both sides of the lower radius. The process of properly seating the seal will stop the leak.
    ~Reposted from an earlier thread same issue HERE.
  10. Roadsmith banner
  11. #9
    Aug 2016
    I removed entire seal which simply pulled away. NO SEALANT OF ANY KIND. NOTHING. NADA. Siliconed entire groove. Had small gap at bottom like Papa zook mentioned. Still leaked at hinges. Removed bottom screws of hinges, flipped up hinge, siliconed, re installed & no more leaks even after a garden hose with sprayer drenching.
    Few days before picking up trike I called & talked with the wife. Very nice & courteous. Asked to make sure everything worked before I drove 565 miles. Upon arrival top right turn signal didn't work. I pointed it out. While waiting on repair one of the employees mentioned out of blue that they don't even remove the top trunk to do conversion. ??? I would love to see that hat trick. The locals seem to love them
  1. Road Smith Trailer
    By bikerbillone in forum Trailers / Campers
    Last Post: 05-16-2014, 09:20 AM
  2. Road Smith
    By bikerbillone in forum General Discussion
    Last Post: 05-26-2013, 06:44 AM
  3. Road Smith Fuel Leak?
    By bikerbillone in forum Honda Trikes
    Last Post: 03-09-2013, 09:45 AM
  4. Road Smith
    By Rosy in forum General Discussion
    Last Post: 07-12-2012, 07:20 PM
  5. Thnx Road Smith
    By 2blackbelts in forum General Discussion
    Last Post: 04-05-2012, 07:00 AM
