Likes Likes:  2
Thanks Thanks:  1
Results 1 to 10 of 10
Thread: Clutch lever not touching the safety switch on my 21 Triike
    650+ Posts Notgrownup's Avatar
    Oct 2021
    Snow Hill NC USA
    Default Clutch lever not touching the safety switch on my 21 Triike
    I have a 21 Tri Glide, I’ve changed the bars and everything seems to work fine, I was swapping the grips this morning and after I reassembled the clutch side, I noticed the lever doesn’t touch or push in the safety switch in the switch pack housing. It’s a cable clutch now and I know that you have to pull clutch in and press any brake to start it in gear. I’m wondering if yours is like that? Or is there a cap or something missing on mine that would make the lever depress the switch.
    Be who your dog thinks you are.
    2021 Tri Glide Ultra Vivid Black with some Farkles.
    Quote Originally Posted by Notgrownup View Post
    Very common problem. If the new grips are a little thicker than the originals, and that will stop the engagement of the switch..
    Just to clarify,..” If” the new grips are just a little thicker than the stock grips that difference will not let the lever,fully engage the safety switch..
    300+ Posts
    Mar 2018
    Waelder, Texas
    I don’t believe there is any difference in the switch function, whether it is hydraulic or cable. When you squeeze the lever, the plunger should be fully extended.When you release the lever, the plunger retracts.
    When the lever is squeezed the trike should start. When lever is released you should be able to set your cruise control. Squeeze the lever and cruise should drop out.
    Do both functions work properly?
    Oct 2021
    Snow Hill NC USA
    Quote Originally Posted by RKplus10 View Post
    I will have to check, it’s on jacks now
    300+ Posts
    Mar 2018
    Waelder, Texas
    Search for a thread titled “A quick and easy cruise control diagnostic check”. You can check all the switches without even starting your trike.
    Oct 2021
    Snow Hill NC USA
    I had Kahuna grips on before and these are about the same size grips as stock so I don’t think it’s the grips.
    Mechanics, 101 go back to the last thing you did before you had the problem!..
    Oct 2021
    Snow Hill NC USA
    that’s the thing, I didn’t have a problem, I’m not sure I do until I get the front end put back together. Will update later.
    Oct 2021
    Snow Hill NC USA
    Well got it all back together and it all works fine… not sure anymore…
  11. #10
    Oct 2021
    Snow Hill NC USA
    Next time I have it at the dealer if ever, I will ask them but I do most of my own work and services. Next is a new or defatted head pipe and a tuner.
  1. Spark plug wires touching
    By keikat2 in forum Harley Tri Glide
    Last Post: 07-30-2019, 06:23 PM
  2. Clutch Lever and Switch
    By Jack Klarich in forum Harley Freewheeler / Road Glide 3
    Last Post: 12-16-2018, 01:52 PM
  3. Location of neutral safety switch on 2013 stallion
    By Rocky330down in forum Stallion Trikes
    Last Post: 09-15-2018, 05:36 PM
  4. Starter safety switch
    By Triker Billy in forum VW Powered Trikes
    Last Post: 09-06-2015, 08:28 AM
  5. Clutch Lever Sensor
    By OlBandit in forum Harley Trike Conversions
    Last Post: 08-31-2012, 07:03 AM
