Likes Likes:  4
Results 1 to 12 of 12
Thread: 2006 CVO with M/T Gladiator with electric reverse.
    80+ Posts Oldrodder's Avatar
    Mar 2018
    Sudbury, on. Canada
    Default 2006 CVO with M/T Gladiator with electric reverse.
    Last year, when storing the trike for the winter, we removed the battery, put a cover on it and put it to bed!!! Fast forward to last week. We took the cover off, re-installed the battery and the trike started right up! I climbed aboard, flipped the reverse switch, pushed on the starter button.....NOTHING! We checked all the fuses and cleaned all the terminals going to the battery and still nothing. We were able to determine that the motor was ok by spinning the drive gear (turns freely) We used a jumper from the battery to the solenoid and the trike reverses. We located the wire (light green)going to the solenoid and found a "no power" situation with the reverse circuit energized. Is there a relay that we can't find? Would anyone have the schematic for the reverse circuit wiring?
    Any help is hugely appreciated,
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Quote Originally Posted by Oldrodder View Post
    Hi Mike,
    Have you checked and reset the reverse breaker switch under the seat? Check that and see if that fixes your problem. If that is not the problem, then remove the MT relay box cover under the seat and check the fuses there. There will be two fuses, a 5 amp and a 7.5 amp. Check and replace if needed.
    Oct 2023
    BODEGA BAY
    I am interested to know if using the electric reverse drains so much power from the battery that the engine stalls. That is what happens to my gladiator trike.
    Mar 2018
    Sudbury, on. Canada
    Hi Mike,
    Thanks for this Pappa Zook! The trike is presently at the local Harley dealer, (The Rock Harley-Davidson) in Sudbury, ON. I'm told they are an authorized M/T installer. They should have access to the schematic for the wiring. When we were checking things we didn't find a breaker under the seat, we did find a fuse box with a cover, under the seat, that held 4 fuses, all 5 amps. About the breaker, would it connect to the light green wire that is connected to the solenoid???
    Mar 2018
    Sudbury, on. Canada
    Issue is resolved. Thanks to Papa Zook for your help.
    Dec 2012
    Santee
    Old Rodder did you know a Jim Robinson from Sudbury? He sold his house in Sudbury a couple years ago and moved to Toronto. (I think.) He used to ride a Kawasaki and then he went to a Gold Wing. He was into riding sleds for a while.
    Ray
    2017 Harley Triglide
    Tijuana Border
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Ok I'm curious now Mike..what was the issue and what was the fix?
    Mar 2018
    Sudbury, on. Canada
    I was the issue!!!! A little history here. I bought this trike late last year and got very little time in the saddle (That's my story and I'm sticking to it!!!!) We're having a rare early spring here in Sudbury, so, the trike came out early. So, long story short, I had a MAJOR brain fart and forgot that I had to press on BOTH the horn and the starter buttons to engage the reverse!!!!! I was reminded of this fact when I contacted Motor Trike.
    The take-away here......I won't soon forget it!!!!
    Mike
    Mar 2018
    Sudbury, on. Canada
    Quote Originally Posted by Rmitchell55 View Post
    No, I have to say, I never met him. Unless, like a lot of bikers, he went by a nickname. I used to hang out at Timmie's on Lorne St where a lot of bikers hang out. Where are you from?
    Mike
  11. #10
    Dec 2012
    Santee
    Old Rodder, I'm in San Diego. He is a friend that I met a number of years ago when we were on a Kawasaki group. Jim and his wife Sandy would come south and attend some of the Kawi rider meet-ups. I guess the first time i met him was in Eureka Springs in 2001. He stills goes by the nickname of "Skid".
    Ray
    Tijuana Border
  12. #11
    Mar 2018
    Sudbury, on. Canada
    No, I never ran into Skid!
  13. #12
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Mike
    Dont feel bad, that happens a lot. Even to guys that have owned their MT Harley for a while. Matter of fact I did the same thing a couple of weeks ago. Pushing and holding both the horn and the starter buttons is definately not an instinctive process.
  1. 2006 Harley Electra Glide, 2006 Motor Trike conversion
    By Wayne Heidelberg in forum Harley Trike Conversions
    Last Post: 04-22-2018, 04:58 PM
  2. CSC electric reverse
    By bflonez in forum California Sidecar Trikes
    Owners Forum
    Last Post: 03-30-2013, 06:14 AM
  3. electric reverse for trike
    By Fabio70 in forum Harley Trike Conversions
    Last Post: 10-15-2011, 03:56 PM
  4. Electric Reverse
    By Ironhorsepilot in forum Harley Trike Conversions
    Last Post: 02-16-2011, 12:42 AM
