Likes Likes:  21
Thanks Thanks:  6
Results 1 to 20 of 26
Thread: engine oil transfer to primary side.
    May 2022
    Warren, ma, usa
    Question engine oil transfer to primary side.
    Last year during a cross country trip, pulling a mini-mate camper, my 2020 tri-glide developed an oil transfer to the primary. It's not the typical transmission to primary transfer, my engine oil goes down as the primary oil goes up. does anyone have ideas as to what might be causing this? FYI, the 2020 came new with the rubber pressure relief installed on the primary side.
    Quote Originally Posted by Gfitzz53 View Post
    Garry........Welcome to Trike-Talk....
    Thats a new one......My X 2017 The transfer....Was trans to the primary....The trans dip stick after every 8 hundred miles or so would read dry....Is the trike still in warranty?...
    3250+ Posts hogmemberisold's Avatar
    Nov 2016
    Shepherdsville, Ky, USA
    Back when I had an ultra classic evo I had engine oil that transferred to the primary and it was the crankshaft seal that was blown crooked. I had to pull the compensator and replace the seal, then life was good.
    May 2022
    Warren, ma, usa
    Default Warranty
    No, not under warranty.
    Always check to see if there is a ''Secret'' Service Bulletin on the problem ....A good service manager can look it up.....Not just off the top of his head....But really look it up...
    Jan 2009
    MA,
    I would bet on the crankshaft seal .
    May 2022
    Warren, ma, usa
    Default crank shaft seal
    I suspect you're right. going to have to open it up to find out. There goes my weekend, was hoping to ride (~;
    1500+ Posts
    Mykneesbehurtin's Avatar
    Apr 2016
    Dayton Ohio
    When Harley installed my vent on my 17 they also replaced the crank seal. after 10,000 miles I haven't noticed any transferring of either transmission oil or engine oil.
    Jan 2009
    MA,
    I just noticed WARREN MASS ? I from the big city of Palmer .
    100+ Posts
    Jun 2022
    South Carolina
    Replace the sprocket shaft spacer and oil seal, items 13 & 19 in the illustration.
    https://www.harley-davidson.com/us/e...a0d2e7700368/y
    US Navy Veteran
    Airframe and Powerplant Mechanic 43 years
    1989 FLSTC
    2019 FLHT
    2022 Tri Glide
    May 2022
    Warren, ma, usa
    Quote Originally Posted by Dan SC View Post
    Thanks, I'll start with the crankshaft seal and look for any other obvious issues.
    May 2022
    Warren, ma, usa
    I moved here just before I retired. now I'm working part time in Palmer. Of course it's scary going into the big city every day (~;
    Jan 2009
    MA,
    We go to warren a few times a week to eat at masons by the police station. What you do for work ?
    May 2022
    Warren, ma, usa
    Factory assembly work at OC White. It's something to keep me busy when I can't ride (~;
    Done working after this month, plan to ride cross country, again, pulling a mini mate pop up camper and a fly rod.
    Jan 2009
    MA,
    factory assembly work at OC White. It's something to keep my busy when I can't ride (~;
    Im on the other side of the river, How do you like are new Bridge ?
    Jan 2009
    MA,
    You have no problem doing the seal ? I could give you a hand ? you need outer primary gasket, 2 inner seals on the inner primary cover, crankshaft seal & oil ?
    May 2022
    Warren, ma, usa
    I don't have the tools to do the seal myself. I did open the primary side, only to find Harley had added the rubber vent already, but that only covers the trany to primary leak. I closed it up yesterday, with new gasket so I can get it to a mechanic. Everyone I've called so far is booked out to end of April or longer.
    Do you have tools for replacing the crankshaft seal?
    Jan 2009
    MA,
    Yes I can do it Butt, I have surgery on the 25th. If that works out I could do it around the first of April ? Stop by my shop one day this week after work ?
  19. #19
    May 2022
    Warren, ma, usa
    I'll stop by tomorrow, I get off work at 11:30, so 11:35 if that's OK
  20. #20
    Jan 2009
    MA,
    OK Thats Good
  1. New fix for oil transfer
    By Mykneesbehurtin in forum Harley Tri Glide
    Last Post: 07-29-2021, 05:57 PM
  2. Doc Harley Video on Harley Oil Transfer
    By Jack Klarich in forum General Discussion
    Last Post: 12-13-2019, 08:15 PM
  3. Hannigan Aux fuel transfer rate
    By kmawing in forum Hannigan Trike
    Last Post: 08-11-2019, 11:41 AM
  4. Question for those with transmission oil transfer issues
    Last Post: 10-17-2018, 05:26 PM
  5. Road Smith Fuel Transfer Problem
    By bikerbillone in forum General Discussion
    Last Post: 02-22-2015, 07:51 PM
Tags for this Thread
