Likes Likes:  4
Results 1 to 5 of 5
Thread: Need help bad with DNA conversion.
    Mar 2024
    Denton Tx USA
    Default Need help bad with DNA conversion.
    I’m converting a 2002 Road King Classic with a mototeks axel, same as the DNA, the biggest thing I need help with is the belt. Mine is a 70T 139T and the belt is short, it looks like the axel needs to move reward by about 2 maybe 3 inches I have no idea what belt size I need for it to work. As you can see in one of the pics the swingarm mounting plates are in the center line of the axel so it has to move back.
    I’m having a few other fitment issues, I’ve searched and searched for pics of trike builds and there are very few videos or images to review, no images of shock mounts, alignment, or anything. It looks like I will have to use a spacer on one of the shocks, I included a pic with the axel brackets that weld to the axel in place, regardless of which side they are on it looks like a spacer will be needed, you can see in one pic the bottom of the left shock is against the pumpkin.
    If I want to use my saddle bags do I have to relocate them, I believe Paughco trikes sells a relocation kit.
    Any information or tips, pics, anything that could help me out.
    Many thanks in advance.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Welcome Kelly,
    Have you tried contacting Mototeks for support on your fitment issues? Was the kit you ordered just the rear axle alone or did you purcase the trike swingarm from them as well? And if so, did they not send the correct swingarm assembly?
    Mar 2024
    Denton Tx USA
    Waiting to hear from Mototeks, will call them again Monday. I ordered the swingarm from them as well, I’m certain it is the correct arm. The belt being to short is the main problem right now, I hope they can tell me which one I will need and I’m having a hard time finding one I think will be long enough.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Quote Originally Posted by TxHarleyRider View Post
    When you find out the size, let me know. I may have the belt you need.
    20+ Posts maniacmac's Avatar
    Mar 2022
    Prescott
    Check the diameter of the pulley compared to the stock pulley. As an authorized trike conversion I have ran into this problem and the pulley on the axle was the wrong diameter. You should have an option on the pulley size.
  1. Calling all CSC kawasaki kruze owners for help bad pully
    By floridaguy in forum California Sidecar Trikes
    Owners Forum
    Last Post: 09-12-2018, 07:44 PM
  2. Bad news. Need Prayers
    By Sunman in forum Thoughts & Prayers Sanctionary
    Last Post: 07-13-2018, 07:07 AM
  3. New member Eleva, WI with bad luck Need advice!
    By razmataz88 in forum New Member Introductions
    Last Post: 06-05-2016, 12:31 PM
  4. Horn is possessed....bad switch? Input (help) is welcome
    By Thor in forum Harley Trike Conversions
    Last Post: 04-23-2016, 02:47 AM
