SSpoon1SSpoonNew Member Introduct...Hello from VA
Likes Likes:  9
Thanks Thanks:  1
Results 1 to 9 of 9
Thread: Greasing a Motortrike Coupe SA rear universal joint
    Mar 2024
    Ocala, Florida USA
    Default Greasing a Motortrike Coupe SA rear universal joint
    Can someone explain how to easily grease the Zerk fitting on the rear universal joint a Motortrike Coupe SA drive shaft? Would a flexible Zerk fitting extension work just to grease it and then remove it and replace the original Zerk fitting? Or do I have to remove the rear universal joint and then the drive shaft from the differential? Any help will be greatly appreciated.
    Quote Originally Posted by Old Aviator View Post
    Anthony’ Welcome to Trike Talk..👍👍..
    Jul 2022
    Edmonton, AB, Canada
    On our 2013 Honda F6B with a Motor Trike kit:
    Jack the rear of the trike, pull off the right side panel below the seat and you should be able to access the zerk fittings (front and rear universal joint zerks). Just rotate the shaft (turn the rear wheels) until the zerks are accessible. A decent light will be of great assistance and it's not overly difficult to access them. I've done it once so far but our trike guy suggests greasing every oil change. It only needs a bit (a squeeze or two). Hopefully this helps.
    Mar 2024
    Ocala, Florida USA
    This is an original drive shaft which has no Zerk fitting on the front yoke going into the transmission. There is a zerk on the rear u-joint, but there is no way to fit a normal grease gun fitting onto that zerk because of the zerk’s position on the u joint.
    I read somewhere that the u joint had to be unbolted from the differential, the moved upward then remove the driveshaft in order to grease the rear zerk fitting. BYW, it can not be accessed by removing the side panel. From underneath only. Or as I said, removed.
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    I beleive only the green front yokes have a zerk. Here and because that front u-joint needs properly inspected, we'd remove the shaft assembly, inspect both joints, and if all good, lube the joints and reinstall the shaft.
    2250+ Posts
    Ocala, Florida
    35-40 years ago I had a riding mower that required a special fitting to get to one zerk fitting. Since I didn't have a name for it I just called it the 'needle nose' fitting that I pushed directly into the spring loaded ball on top of most zerk fittings. Worked like a charm, hope this helps your problem.
    Beware of liberals posing as Americans.
    Mar 2024
    Ocala, Florida USA
    Great suggestion! Thanks.
    Mar 2024
    Ocala, Florida USA
    Thanks for the advice.
    Sep 2016
    Springfield, Mass. USA
    I just grease'd up my Roadsmith TRIKE yesterday.......... I jacked up the rear end, and spun the wheel untill the grease jurks were visible (and easy'ly exposed,) and placed a grease gun into the jurks, and pumped only two pumps of grease.......... Then clean area where the grease expands. Easy Peezy! I do this the beginning of every ride'n season!
    4/12/24
  1. Replies: 1
    Last Post: 07-17-2016, 09:22 AM
  2. Rear rim size Motor trike coupe
    By Warlock in forum Honda Trikes
    Last Post: 11-03-2015, 08:23 PM
  3. Greasing Lehman Monarch II trike
    By Tinman701 in forum Honda Trikes
    Last Post: 07-07-2015, 07:27 PM
  4. Greasing the drive train?
    By Lady Triker in forum Harley Tri Glide
    Last Post: 09-29-2014, 03:46 PM
  5. Greasing differential on rigid axle HD trike
    By engprosinc in forum Harley Trike Conversions
    Last Post: 07-24-2013, 07:53 PM
