Davep3KoolbreezeHarley Tri GlideTRI GLIDE AIR FILTER QUESTION
Davep3rhino 2Harley Tri GlideTRI GLIDE AIR FILTER QUESTION
Davep3DavepHarley Tri GlideTRI GLIDE AIR FILTER QUESTION
Likes Likes:  0
Results 1 to 6 of 6
Thread: 2011 Tri glide mufflers
    10+ Posts
    May 2011
    Newark, De. USA
    Default 2011 Tri glide mufflers
    I always thought I was quit good at wrenching. But I am stumped. I just purchased a set of V&H double slash down rounds. I have changed many sets of mufflers in the past but when I got to my 2011 Tri glide I for the life of me can't figure out how to get the stock mufflers off. I can't get a wrench at to bolt closest to the back of the bike. Am I missing something?????
    1000+ Posts
    Mar 2011
    Muncie, Indiana
    Default Re: 2011 Tri glide mufflers
    The first time I removed mine I had to loosen clamp holding muffler in front. Then with a small 1/4 ratchet, loosen the front bolt at rear. This allowed me to slip muffler back a bit to get the small socket setup on rear bolt.
    I can not think of a harder way to mount mufflers. Leave it to harley.
    Hope this helps.
    Dennis
    30+ Posts
    May 2011
    Napoleonville, La
    This is for Harley mechanics to spend time fighting this problem. It never fails to amuse me to see what "intelligent" designers do to accomplish a very easy solution to problems. From special tools to inaccessible fastner locations one wonders WHO is actually "drinking" on the job.
    10+ Posts
    May 2011
    Newark, De. USA
    The problem was that the rubber bushing that runs through the channel on the mounting bracket should be centered between the two nut locations on the muffler. On mine the rubber bushing was pushed to one side covering the bolt head. I was unable to get a wrench or socket on the bolt. I spent (4) hours cutting away the rubber with a razor knie to gain access to the bolt head. Now I need two new rubber bushings. I hope they don't cost HD,(hundred dollars).
    4750+ Posts msocko3's Avatar
    Sep 2009
    NE Ohio
    I believe it was through the mid 2010 MY when HD changed the design of this rubber part because the other one was popping out of the metal bracket causing the muffler to rattle. I agree it is a step in the wrong direction for the Trike. I replaced the old style on my 2010 and have had the same problem with the longer rubber riding onto the bolt. I took a long handled flat blade screwdriver and managed to use it to knock the rubber out of the way with a hammer.
    http://i1347.photobucket.com/albums/...pswnuweejq.jpg
    Red Ultra Powered By Head-Quarters 120, Easy Clutch Pull By ClutchWIZ. 2012 GL1800 Hannigan. I've yet to ride a stock Harley which wasn't in need of a mechanical intervention.
  6. DKCustoms postbit
  7. #6
    600+ Posts 427dave's Avatar
    Jan 2011
    The Villages, FL
    I changed my mufflers also and believe it would be quicker and easier to remove the body. On the 2011 my rubber piece had slipped to the rear covering the bolt head also. Not a fun project.
  1. 2011 TriGlide Mufflers
    By OlBandit in forum Harley Tri Glide
    Last Post: 03-02-2012, 12:57 PM
  2. 2012 Tri-Glide Mufflers
    By Hoghead in forum Harley Tri Glide
    Last Post: 12-05-2011, 01:14 PM
  3. 2011 Tri Glide - Loose oil pan!
    By ehroyal in forum Harley Tri Glide
    Last Post: 10-15-2011, 08:43 PM
  4. New Handlebars on the 2011 Tri Glide
    By MontgomeryLittle in forum Harley Tri Glide
    Last Post: 08-15-2011, 08:48 AM
  5. 2011 Tri-Glide Heat
    Last Post: 08-12-2011, 07:58 AM
