14TG114TGHarley Tri GlideInstallation of a new Fuel Filter &...
BigN693GorillaEnabled TrikersFull length floorboards
Results 1 to 14 of 14
Thread: VW Trike W/Auto Trans
    Jun 2011
    Mena, Arkansas, USA
    Default VW Trike W/Auto Trans
    Anybody had any experience with the VW automatic transmission?? Just curious as to how folks feel about the auto trans.
    VW Tech Expert Loner's Avatar
    Aug 2010
    Harvest, AL USA
    Default Re: VW Trike W/Auto Trans
    VW full automatics (as came in Type III's - squarebacks) are quite bulletproof and well worth the extra effort if you are building a trike. If you speak of the 'auto-stick' as was used in the Type I (Beetles), then they are not quite as big of a hit (some say they are not smooth on a trike, have more problems, etc.) but are used often with great success. I think a nice trike could be made with either type, but I like the full-automatics best myself.
    Jun 2011
    Mena, Arkansas, USA
    Sounds good, makes it simple for my partner to take over as pilot.
    Quote Originally Posted by jeffmcdonald View Post
    Bought one with the full-auto for the daughter. She loves it.
    Mar 2011
    Sacramento,CA USA
    I have been building VW based Trikes since 2001 and have built several using the VW full automatic. Frankly, I wouldn't own anything but a full automatic. I just hate shifting all the time.
    For the past few years, all my builds have been VW automatics adapted to a Subaru 1.8 SOHC motor. This has proved to be a very nice combination. A very nice smooth working automatic, coupled up with a great little motor that is nearly maintenance free.
    My wife and I both ride a Homebuilt with the VW auto and Subaru motor. We just love them. As it happens, I have an extra one on hand at this time.
    50+ Posts
    New Jersey
    Quote Originally Posted by trikerbob59 View Post
    do you have photos, or a website ...?
    60+ Posts
    Sep 2008
    clarksville
    i got one.full auto.put it in drive and go.didn't realize it at the time i got it,it had a bent dipstick mount that let lots [LOTS] of water into tranny case figured it out when it started leaking water out of the dipstick mounting hole.drained 2 and1/2 gallons of pink icecream out of the case.pulled the pan, [fixed the mount of course]drained it for a day,new gasket and 12[yep 12]fluid changes later,the fluid remained clear and red when drained.no prob in shifting,smooth pull all the time.only prob is the cable.put it in 2[or 1,which ever is furtherest from park[didn't get a shift indicator with it] ],come back to drive and go.otherwise it's not completely in drive.otherwise,great ride.very happy with it.
    200+ Posts
    May 2011
    Orlando,Fl--USA
    I have talked to several pro trike builders and they all said the same thing---
    Type III-Squareback full auto trans are great and hold up well.
    The Auto-Shift trans--not so good.
    200+ Posts
    May 2011
    Orlando,Fl--USA
    Trikerbob59,
    when you said that you had "an extra one on hand..."
    What exactly did you mean?
    That you had a running trike on hand or a Subaru engine or a VW auto trans or
    both the engine AND trans?
    Thank you.
    80+ Posts Buggie Pilot's Avatar
    Mar 2010
    Stafford Springs,Ct.
    No problem With the Autostick *EVER* in our vw trike. Put it in third ride ALL DAY never shift .... not once ( they were designed to pull a lot more weight than just a trike.)
    [SIGPIC][/SIGPIC]
    Honored to be a member of the
    Connecticut Patriot Guard
    Pete G
    100+ Posts rrunner's Avatar
    Oct 2010
    Zuni, New Mexico, USA
    I believe Trikerbob59 has a complete trike with the full auto trans and Subaru engine for sale if he hasn't sold it yet. He has a website which goes through the process of the build. I hope I'm not stepping on your toes Bob. My Subaru Trike Project
    Jun 2022
    Goreville,Illinois,USA
    Default VW auto transmission on my trike
    having trouble with my auto transmission shifting into third gear on my trike any suggestions
    Founder: Roadsmith Trikes
    TrikeTalk Sponsor
    May 2016
    Daytona Beach Fl
    Default Mr Trike
    Quote Originally Posted by Bones of Illinois View Post
    Check oil level running hot in neutral. next remove vacuum line from modulator valve to see if any trany oil in it. Could be bad modulator valve. Needs replacing. KEEP-N-TRIKEN
    50+ Posts MikePerrone's Avatar
    May 2017
    Las Cruces, NM
    I have a Roadhawk with a automatic transmission and I love it!! I would never want to go back to a standard transmission, sepecially since I do alot of around town driving, that would be alot of shifting I don't want. Lesson learned, keep an eye on the fluid,I did have a Runabout that had tranny issues but I think that was because a leak went undetected.
  1. can a VW based trike with auto trans be towed?
    By eagle42101 in forum VW Powered Trikes
    Last Post: 01-12-2013, 12:27 PM
  2. 2004 ultra trike trans
    By kc8nur in forum Harley Trike Conversions
    Last Post: 07-06-2012, 10:08 PM
  3. V8 Trike Trans. swap
    By haigcomp1 in forum Home Built Trikes
    Last Post: 06-01-2012, 02:45 AM
  4. 4th gear for VW auto Trans
    By jeffmcdonald in forum VW Powered Trikes
    Last Post: 11-25-2011, 07:00 PM
