Results 1 to 5 of 5
Thread: Motor Trike Brakes
    Jul 2011
    Wetumpka, AL
    Cool Motor Trike Brakes
    My girl has a VTX 1300 R with the Motor Trike conversion (used). We are going to do a brake job and would like to know if anyone can tell us what type brake shoes / pads we will need. I saw a reference on this site to a ford ranger axle, is that what they used on this???<br />
    <br />
    The Damned Yankee
    Sep 2009
    Near Myrtle Beach SC
    Default Re: Motor Trike Brakes
    It should be Ford Ranger or Mustang 8.8 rear end and brake shoes. How many miles are on it? I would think you would only have to adjust the slack adjust for the shoes for better braking and be done with it.
    The only issue I had in 40k miles so far is the cable inside the drum assembly one brake broke but it was a $15 repair using a Autozone brake kit
    If the drum pull off easy check your shoes for any issues but all you should have to do is turn the slack adjuster out enough to make it snug pushing the drum back on
    Jul 2011
    Wetumpka, AL
    Thanks FLTR2008TRIKE.
    I also got a link to a site from NANNA(?)
    Thanks again to all for your input.
    DMDYANK
    40+ Posts
    Jul 2011
    Minneapolis,Minnesota, USA
    WHY don't you post the Site you got for Brake Shoes so the rest of us will know.... Thanks
    7250+ Posts Nana's Avatar
    Apr 2008
    Ohio
    I just directed him to a thread that is already clearly posted here. It has a link to a PDF service manual for Motor Trike that can be printed off or read on the computer. Here is the link to that thread: <a href="http://www.triketalk.com/forum/honda-trikes/315-motor-trike-service-manual-finished.html" target="_blank">http://www.triketalk.com/forum/honda...-finished.html</a>
    Trike Talk Membership Map
    No matter the storm, when you are with God, there is always a rainbow waiting.
    http://i440.photobucket.com/albums/q...andana-1-1.jpg
  1. Drum Brakes for Lehman Suzuki C90 Trike
    By c90 Jackal in forum Suzuki - Kawasaki Trikes
    Last Post: 06-09-2023, 08:38 AM
  2. New user needs help with Motor Trike brakes
    By yamadawg in forum Honda Trikes
    Last Post: 01-04-2020, 10:05 PM
  3. Rear brakes on 1991 mt trike
    By polarsue in forum Honda Trikes
    Last Post: 06-08-2013, 10:12 AM
  4. Trike rear brakes
    By dsifford in forum Honda Trikes
    Last Post: 11-14-2012, 09:24 PM
  5. VW trike back brakes
    By greg will in forum VW Powered Trikes
    Last Post: 12-24-2011, 10:41 PM
