SSpoon9Marc HNew Member Introduct...Hello from VA
SSpoon9ZammyNew Member Introduct...Hello from VA
SSpoon9Uncle FesterNew Member Introduct...Hello from VA
SSpoon9rhino 2New Member Introduct...Hello from VA
SSpoon9trike ladyNew Member Introduct...Hello from VA
SSpoon9SullyNew Member Introduct...Hello from VA
SSpoon9Jack KlarichNew Member Introduct...Hello from VA
SSpoon9GorillaNew Member Introduct...Hello from VA
SSpoon9SSpoonNew Member Introduct...Hello from VA
Likes Likes:  0
Results 1 to 5 of 5
Thread: Larry H
    1+ Posts
    Jul 2011
    Alma Michigan USA
    Default Larry H
    I have been told that if I convert my bike to a trike I do not need to install the ez steer to it as it has rake enough and this would not help the steering that much, 2008 Venture. Anybody know for sure?
    T.O.I. - Florida jfingalls's Avatar
    May 2010
    Ormond Beach, Florida USA
    Default Re: Larry H
    Welcome Larry again. Just saw your post in another string. When I converted my GW the installer told me to wait and see if I thought that it (rake) would be needed before spending the $1200. He was right, I'm fine without it for the past three years. Just keep the front tire above 40 psi.
    2021 Can-Am Spyder RT,
    TOI
    1000+ Posts CCrider's Avatar
    May 2010
    Southern Ohio, USA
    Default Re: Larry H
    Larry , Welcome to the best darn trike forum on the net. I think it going to be personal preference. I added the rake kit to my GL 1500 and it was like adding power steering to a dumptruck. I got mine from ZOOK (on this forum) and saved mega bucks.
    350+ Posts trikerslave's Avatar
    Jan 2011
    Greenfield, In
    Default Re: Larry H
    Welcome.......................................... utergreet:
    [SIGPIC][/SIGPIC]
    ___________________________________________
    One Of The Origionals
    TOI - New England
    John Luciano's Avatar
    Mar 2008
    Conn
    Default Re: Larry H
    I have a DFT Goldwing 66,000 miles no rake . It is heave steering but far from impossible to handle. Hair pin turns and some On ramps can cause it to be heavy, but normal twistys are not a big problem . As said try it with out . It is the same $ to add it later. It is on the front of the trike so it is not part of the install.
    Don't be too quick to pre judge it . It takes 1,000 miles to get use the the trike. If after 1,000 miles you feel it is still to much than have it done.
