Results 1 to 5 of 5
Thread: Little Help Please !
    10+ Posts RLJO's Avatar
    Mar 2010
    Salisbury,NC
    Default Little Help Please !
    Just look at a VW Trike. Was not running but the guy said the timing was off.
    He said the engine was 1500 VW 1961. Had Harley front end all chrome with some rust. He said he wanted $2500.00. I said I was leaving because I could not afford it. He then said $1500.00. Is this a good deal or not. Any info will be greatly appreciated.
    RLJO
    What goes around comes around!!!:)
    RLJO
    1250+ Posts katfish16's Avatar
    Feb 2008
    Gallion, Alabama
    Default Re: Little Help Please !
    Beware, timing takes about 5 minutes to do if u know what u are doing. Could be more wrong than timing.. Get someone to check it out for u who knows about VW,s.
    Good luck
    Steve & Cathy
    Alabama
    U.S. Coast Guard (retired)
    I second Katfish. VW engines are very very basic. I would suggest that whatever you decide it should include a replacement engine. The 1600 dual port engine was a much better engine. Good luck
    7000+ Posts Lucky's Avatar
    Dec 2009
    LaFayette
    Sounds like he sure did drop that 1000 quick.I would wanna hear it run.Good Luck
    200+ Posts vwmaniac's Avatar
    Jul 2011
    Gresham,Ga. usa
    Sounds like a bit much for it and not running, a good old single port 1600 motor is sometimes better than a dual port,[better mileage]
