Results 1 to 10 of 10
Thread: Tow Pac adjustments
    Sep 2011
    Mt Laurel, NJ 08054, USA
    Default Tow Pac adjustments
    I have recently reinstalled my Tow Pac on my GL1800. I do not have the manual that came with it. I would like to get one so that I can do a correct set-up. Help.
    Default Re: Tow Pac adjustments
    Quote Originally Posted by Abrian1937 View Post
    Welcome aboard. Did you try Tow-pac for a manual?
    Sep 2011
    I went online but found no sites to order or download a manual. I Suspect that I will have to call them. I just thought someone might have one and could fax or email a copy.
    Thanks for your quick reply.
    Brian
    300+ Posts dadztoy's Avatar
    Dec 2011
    Georgetown, Tennessee, USA
    Brian, are you still looking for a Tow Pac manual??? If so, send me a private message and I'll get your FAX number or e-mail address...
    Les
    Jan 2014
    Port Lavaca, TX USA
    Quote Originally Posted by dadztoy View Post
    Les
    Hey, Les
    I need a Tow Pac Manual and saw this one you sent to Brian. Can you email the manual to me, hanknovak@cableone.net?
    100+ Posts
    Jan 2011
    illinois
    Tow-Pac will send you a manual if you call. Don't know what they would charge though. You can also find adjustment instructions on-line.
    Dec 2011
    Quote Originally Posted by hanknovak View Post
    Hey, Les
    Hank,
    Brian never responded to me and we have just moved... I can send you a manual if you can wait a while - we just made the move to Tennessee and are currently "living out of boxes" and I have no functional scanner/copier yet... We live in a fairly rural area (about 2 hours from "The Dragon" and other great roads!!!) so getting into town to use a copier and/or post office isn't real easy like it was when we lived in suburban Chicago Once I get the scanner going I can just scan it and send you the files...
    If you need it right away, you might want to consider calling Tow Pac - if you can wait a bit (2-3 weeks) when I buy my new all-in-one printer/scanner/copier, I can get it to you...
    Les
    20+ Posts cblack6540's Avatar
    Feb 2010
    Port Richey , FL
    try this link http://www.whereispdf.com/view/79498/contents
    if if doesnt work just search for Tow Pac Installation manual on the net thee are several free to download and the adjustments are the same (after initial installation) for all bikes....
    Jul 2017
    Catskill, NY
    Default I also need a towpac manul.
    Hey, Les
    Can you also email me a manual. I need to adjust mine , purchased on bike used and Towpac has not returned my message. THANX
    jnriii@msn.com
    Dec 2011
    Quote Originally Posted by JNRIII View Post
    jnriii@msn.com
    Hank, I've been on a MC trip out west... Refresh my "old man" memory please - did I send you the manual???
    Les
  1. HeimJoint adjustments
    By Jimsjinx in forum Honda Trikes
    Last Post: 04-26-2022, 06:45 PM
  2. rear drum brake adjustments Lehman
    By engprosinc in forum Harley Trike Conversions
    Last Post: 06-10-2013, 12:20 PM
  3. h-d ext. wattenty doesn't cover adjustments
    By eagle1 in forum Harley Trike Conversions
    Last Post: 06-08-2012, 12:41 AM
  4. Aero 750 Motor Trike Suspension Adjustments
    By skuuter in forum Motor Trike
    Last Post: 07-31-2010, 10:01 PM
