Results 1 to 2 of 2
Thread: '09 T/G which true duals? oil temp 250*
    750+ Posts
    May 2011
    peru,in,usa
    Default '09 T/G which true duals? oil temp 250*
    i also run the revolution performance EFI. Have S&S 510 gear cam too. just want cooler oil temp if possible. thanks
    Sep 2009
    Near Myrtle Beach SC
    Default Re: '09 T/G which true duals? oil temp 250*
    I 08 triked bike but run V&H true dual exhaust with V&H Monster Ovals. Your head pipe is different but FuelMoto make a head pipe and so does Fullsac which will work with your exisitng heat shields while giving you better exhaust flow and reduced heat
  1. Replace air temp gauge with oil temp gauge
    By gamechngr in forum Harley Trike Conversions
    Last Post: 03-04-2014, 12:09 AM
  2. V&H Power Duals and Manual Reverse
    By Ride4Him in forum Harley Trike Conversions
    Last Post: 03-14-2013, 11:42 PM
  3. True Duals
    By gbsb in forum Harley Trike Conversions
    Last Post: 10-01-2012, 07:47 PM
  4. Power Duals??
    By wimoonshiner in forum Harley Trike Conversions
    Last Post: 01-18-2012, 08:15 AM
  5. true duals for tri glide?
    By rog1215 in forum Harley Trike Conversions
    Last Post: 10-29-2009, 03:46 PM
