Results 1 to 6 of 6
Thread: AT with 1600
    Jun 2011
    Mena, Arkansas, USA
    Default AT with 1600
    I just bought a VW trike with a 1600 engine and auto trans. The engine seems to be pretty well shot. I am going to fix the engine. Here is the question, I want to tow a pop up camp trailer. Should I go to an 1800+ engine or will the 1600 do the job?? Also, when towing on a regular basis, should I add an oil cooler to the trans and engine. Also, will the 1800 fit on the auto trans?
    Well it started out as one question
    rovingjeff
    200+ Posts
    May 2011
    Orlando,Fl--USA
    Default Re: AT with 1600
    I have a stock 1600 and pull a small trailer (4' wide--5' long--30" high)
    Fully loaded, it was right at 450 lbs.
    The trike did not even know it was pulling a trailer.
    I do NOT have an oil cooler--but have a filter relocation kit with a standard oil sump.
    The temp gauge hardly moved as we were pulling the trailer in 98* heat here in Florida.
    I imagine that it all depends on the total weight of the trailer and the tongue weight.
    If you are rebuilding the engine, why not go bigger?
    My building buddy has an 1835 WITH a turbo and it it extremely reliable and will pull tree stumps.
    He does have an oil cooler. He said that the turbo adds a lot of heat.
    Best wishes.
    Mike
    Ride safe!!! Lots of idiots out there!!!
    20+ Posts wics51's Avatar
    Feb 2011
    Waynesboro, Virginia, USA
    One thing to note is the cam, if it is the full automatic, it shifts off of vacuun pressure amongst other things, and a cam will change the vacuum and will definitely affect shifting.
    VW Tech Expert Loner's Avatar
    Aug 2010
    Harvest, AL USA
    Controversial questions, but here's my two cents worth. Based on the VW's gearing (quite low geared particularly considering you've just dropped 2000 pounds from the body), stock is adequate and most dependable. A couple of mods (better exhaust and carb) will be a good investment, but not a necessity. No such thing as an additional gear for the automatic that I've ever heard about. Any size engine will bolt up to the tranny so long as you don't change the flex plate or crankshaft end (no special tapered crank, etc.).
    Short answers, just my opinions, but I am quite open to disagreement. Stock or nearly stock is enough for me and I've pulled trailers all over.
    200+ Posts vwmaniac's Avatar
    Jul 2011
    Gresham,Ga. usa
    Quote Originally Posted by Loner View Post
    Loner,
    you are right, no gears to be changed in the auto, at least not to my knowledge and any vw motor will bolt up to the trannie.
    80+ Posts Buggie Pilot's Avatar
    Mar 2010
    Stafford Springs,Ct.
    True an autostick can be bolted to any aircooled vw, but there are 2 things that must be observed;
    1.) The cam plug on the flexplate side must face in. If it is out like the manual trans. setup the flexplate has been known to wear through it. ( Here is a link to some discussion and pictures over on THE SAMBA )
    2.) There are two different oil/atf pumps made. One is for a flat cam gear and the other is for a dished gear. You need to know which pump you have as they are NOT interchangeable .
    The other thing that was a question of concern was about adding a cooler to the TRANS FLUID side. The autosticks had one or even two temp sensors on them. These indicated that the atf was getting warm and it was time to downshift. In my opinion with the power of the 1800cc motor and the weight of the trailer, an oil cooler would let you stay in high gear longer with a lower atf temp. I dont believe it is required, but for the cost and ease of installation I would be putting one on my custom build
    Good Luck
    Pete G
    [SIGPIC][/SIGPIC]
    Honored to be a member of the
    Connecticut Patriot Guard
    Pete G
  1. starter gear teeth 12v 1600 vw of the gear
    By bluedog in forum VW Powered Trikes
    Last Post: 07-24-2013, 04:22 PM
  2. 1600 Rebuild for new trike
    By usnavy8084 in forum VW Powered Trikes
    Last Post: 09-03-2012, 12:20 PM
  3. 1600 roadstar, front brakes
    By jmhelm in forum Yamaha Trikes
    Last Post: 05-18-2011, 04:58 PM
  4. vulcan 1600 classic to trike
    By bulldog in forum Suzuki - Kawasaki Trikes
    Last Post: 03-12-2011, 05:49 PM
