LD-Ordie6trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie6SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Results 1 to 7 of 7
Thread: 4th gear for VW auto Trans
    Jun 2011
    Mena, Arkansas, USA
    Default 4th gear for VW auto Trans
    I have heard there is an add-on 4th gear for the VW auto trans. Anybody know anything about that??
    200+ Posts vwmaniac's Avatar
    Jul 2011
    Gresham,Ga. usa
    Default Re: 4th gear for VW auto Trans
    Never heard anything about that?
    200+ Posts ea81slush's Avatar
    Nov 2011
    Strathbogie Victoria Australa
    not heard that either. My trike had standard 295/50/r15 tyres. It revved too high at cruising speeds. Changed to 275/60/r15 tyres- 5% more circumference. lowers revs about 200 at 60mph. This could be considered especially with the VW engine.
    Now I'm going back to the old size due to towing a trailer with subaru ea81 now as my powerplant. more power and revs better but too high geared for towing weight.
    1000+ Posts Rsw's Avatar
    Sep 2011
    Little Hocking, Ohio
    Can you change ring and pinion gears in them like you can a standard?
    Nov 2011
    I really dont know. What I do know is that when I did my research on converting to Subaru ea81 Brat/Brumby engine I found that the 3 gear ratios in the VW auto were almost identical to the Subaru Leone auto sedan on the 1980's here in Oz. So the brilliance of Subaru and VW engineers would have gotten the ratios at their best when they designed the auto in the first place. There are some things that should eb left as they are in my view and gear ratios in an auto is one of them. However:
    There is a guy in Queensland Australia calls his web site www.subarugears.com and he makes reverse crown differentials in Subaru transaxles to fit Subaru engines that are mounted at the rear of vehicles. You can email him. Even with a VW engine you could get an adapter plate to a Subie transaxle and have 4 or 5 speed auto or 5 speed manual Subaru gearbox set up. He'll ship around the world.
    Sep 2011
    Emailed a trans shop that is going to build my trans axle and he said if it's a 4 speed autostick, you can change the gears in it. They are just like a standard but with a torque converter. But a full automatic you can't do anything to change the gear ratio.
    Nov 2011
    sounds logical RSW. thanks for the information
  1. VW Trike W/Auto Trans
    By jeffmcdonald in forum VW Powered Trikes
    Last Post: 06-30-2022, 01:52 PM
  2. Trans oil capacity
    By Lakeman in forum Harley Trike Conversions
    Last Post: 09-07-2013, 12:05 PM
  3. starter gear teeth 12v 1600 vw of the gear
    By bluedog in forum VW Powered Trikes
    Last Post: 07-24-2013, 04:22 PM
  4. can a VW based trike with auto trans be towed?
    By eagle42101 in forum VW Powered Trikes
    Last Post: 01-12-2013, 12:27 PM
