gfaltersack7rhino 2Harley Tri GlideDK Customs remote oil filter kit in...
gfaltersack7gfaltersackHarley Tri GlideDK Customs remote oil filter kit in...
hardwickbv1hardwickbvHarley Tri GlideGot a Code P0152 Engine Running Ric...
dthorn4dthornHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn4Papa ZookHarley Tri Glide2024 Tri Glide front axle nut torqu...
SSpoon14cycle7447New Member Introduct...Hello from VA
Richard D12CorkeykHarley Trike Convers..."Himsl Praying Mantis" Sh...
gfaltersack7ISP-FLHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon14hardwickbvNew Member Introduct...Hello from VA
gfaltersack7TFNCHarley Tri GlideDK Customs remote oil filter kit in...
dthorn4nucsealHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn4TrampasHarley Tri Glide2024 Tri Glide front axle nut torqu...
gfaltersack7Phu CatHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack7Old Road DogHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon14woodyNew Member Introduct...Hello from VA
SSpoon14hogmemberisoldNew Member Introduct...Hello from VA
SSpoon14ol' schoolNew Member Introduct...Hello from VA
SSpoon14Marc HNew Member Introduct...Hello from VA
SSpoon14ZammyNew Member Introduct...Hello from VA
SSpoon14Uncle FesterNew Member Introduct...Hello from VA
gfaltersack7DK Custom ProductsHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon14rhino 2New Member Introduct...Hello from VA
SSpoon14trike ladyNew Member Introduct...Hello from VA
SSpoon14SullyNew Member Introduct...Hello from VA
SSpoon14Jack KlarichNew Member Introduct...Hello from VA
SSpoon14GorillaNew Member Introduct...Hello from VA
SSpoon14SSpoonNew Member Introduct...Hello from VA
Likes Likes:  2
Results 1 to 12 of 12
Thread: New user needs help with Motor Trike brakes
    Knoxville TN
    Default New user needs help with Motor Trike brakes
    I have been combing the forums and have not found a defiinitive answer, so I thought I'd throw this out there. My wife's 1300 VTX has a Motor Trike conversion, and while I was changing out the air bags this morning I see that one of the wheel cylinders is leaking. I was hoping someone could tell me how to find out what part number the wheel cylinder is. I saw the documentation in the manual that is available here on the site. (A GREAT resource, I might add.)
    The manual shows a rear end that has four bolt lugs, but this super sport Motor Trike rear end came with a five bolt set up, so I assume the brake parts may be different. Also, on the maintenance manual the same part number is listed for both the wheel cylnder and the adjuster for one side. I have seen references that range from Ford Ranger to Mustang, but no specifics. We questioned Motor Trike reps at Sturgis and Daytona, called them, and also tried several of their "dealers" and are coming up with dead ends... Please someone, help...
    Default Re: New user needs help with Motor Trike brakes
    Quote Originally Posted by yamadawg View Post
    I have been combing the forums and have not found a defiinitive answer, so I thought I'd throw this out there. My wife's 1300 VTX has a Motor Trike conversion, and while I was changing out the air bags this morning I see that one of the wheel cylinders is leaking. I was hoping someone could tell me how to find out what part number the wheel cylinder is. I saw the documentation in the manual that is available here on the site. (A GREAT resource, I might add.) The manual shows a rear end that has four bolt lugs, but this super sport Motor Trike rear end came with a five bolt set up, so I assume the brake parts may be different. Also, on the maintenance manual the same part number is listed for both the wheel cylnder and the adjuster for one side. I have seen references that range from Ford Ranger to Mustang, but no specifics. We questioned Motor Trike reps at Sturgis and Daytona, called them, and also tried several of their "dealers" and are coming up with dead ends... Please someone, help...
    Sorry I can not help but can I suggest going to NAPA. At least my NAPA guy recognizes alot of parts that I could not identify.
    TOI - Pennsylvania White Knight 04's Avatar
    Sep 2010
    Rockland Pa. USA
    Can't help would like to find this out myself... I think stepping on a plumb would be more like the way I think of my brakes on motor trike, the front are great Harley originals ,but the rear motor trike brakes are almost useless to say the least !!!
    Never ride faster than your angel can fly !!
    Jerry & Linda
    Penna TOI ContactTOI #245
    2008 103 true duels, Master tune by TTS, Motor Trike I.S.Gladiator kit
    [SIGPIC][/SIGPIC]
    150+ Posts grumpy's Avatar
    Aug 2010
    Colorado Springs, CO USA
    Remove the wheel cylinder & take it to NAPA. They should be able to match it up & sell you a new one or a rebuild kit. The kit will be much cheaper & is not a hard job to install.
    300+ Posts Chumbly's Avatar
    Apr 2010
    Surrey. B.C., Canada
    I believe I have the info here somewhere, and will try to dig it up...I think the MT/VTX1300 kit is exact same as the VTX1800... with the flipped diff, and 80's Mustang brakes. I believe MT sent me the brake part numbers...just to find them.
    Apr 2010
    Ho'kay here it is-
    Part # Vender
    Brake Shoe- PAB 474R Wagner
    Brake drum- BD 60355 Wagner
    Auto Adjust kit- F98414S Wagner
    Auto Adjust Kit- F98415S Wagner
    Wheel Cylinder- F354876 Wagner
    Combi-kit Hardware- F78550S Wagner
    U-Joint- 369 Precision
    Yoke- 2-4-583 Spicer
    Flange- 2-2-939 Spicer
    Axle seal- 8660 S National
    Rear Cover Gasket- RDS 55081 Fel Pro
    Pinion Seal- PT 3604 National
    Axle Bearing- R 1563 Fed Mogle
    For what it's worth, the sheet says this is the parts listing for a 7.5 Ford. And, it's a 5 lug bolt pattern on mine as well. Hope this helps ya out.
    Tour Captain - Contributing Member Big_Steve's Avatar
    May 2010
    Southwest Florida
    Quote Originally Posted by White Knight 04 View Post
    Something's wrong. The rears on my 1300 VTX motortrike were quite strong.
    Big_Steve AKA "Chiefy"
    2006 Honda VTX 1300 S Motor Trike. "Maryann" She got me back into riding. Gone, but never forgotten.
    1998 Valkyrie standard (2 wheel) "R'ota"
    [SIGPIC][/SIGPIC]
    May 2010
    Southwest Florida
    Are you sure it's the rear brake cylinder? I ask because I had fluid on the ground once. When I pulled the drum, the rear end seal was leaking into the drum.
    [SIGPIC][/SIGPIC]
    Sep 2010
    Rockland Pa. USA
    No drums on mine it is disc brakes as you can see it is the new gladiator independent suspension !!! My builder even re bled them and they still are not up to par !!!
    Jerry & Linda
    [SIGPIC][/SIGPIC]
    300+ Posts Calman's Avatar
    Jun 2009
    Whortonsville, NC
    Might considering taking a look at the flange of the brake line where it goes into the cylinder. I was losing brake fluid on a regular basis on the Shadow until a local mechanic changed the flange from flair to a bubble flange. It's been over a 1,000 miles sinice the repair and I've not added a single drop of fluid.
    TOI - Michigan retdpd's Avatar
    Mar 2008
    Eastpointe
    I did work on a HD w/motor trike conversion I took the part to Autozone it was a n easy match up....
    Apr 2010
    Shenandoah Valley of Virginia
    When taking parts to parts man, might help to suggest he look at applications that use 9" Ford Drum Brakes. Used different sizes of wheel cylinders. Used on both 4 and 5 lug pattern axles like Ford 6.75" integral (integral rears have cast center with tubes pressed in & plug welds and a rear inspection plate) (Pinto, etc), 7.5" integral (T-birds, Mustangs too) or older 8" rear with a cast hogshead that drops out front (CSC & MT both used them years ago). So far, I haven't seen the old very stout & heavy Ford 9" rear or later 8.8" integral rear used in a trike. Even the 8" rear is heavy, but it is lighter than the 9" rear. There are bigger 10" drums, but I have never heard of them on a trike yet.
  1. new user
    By Bill Gray in forum Honda Trikes
    Last Post: 01-20-2012, 08:36 PM
  2. new user
    By phil1945 in forum Honda Trikes
    Last Post: 01-19-2012, 06:30 PM
  3. New User From Texas
    By joelmcbride in forum New Member Introductions
    Last Post: 08-23-2011, 08:34 PM
  4. Motor Trike Brakes
    By dmdyank in forum Motor Trike
    Last Post: 07-14-2011, 08:56 PM
