SSpoon9Marc HNew Member Introduct...Hello from VA
SSpoon9ZammyNew Member Introduct...Hello from VA
SSpoon9Uncle FesterNew Member Introduct...Hello from VA
SSpoon9rhino 2New Member Introduct...Hello from VA
SSpoon9trike ladyNew Member Introduct...Hello from VA
SSpoon9SullyNew Member Introduct...Hello from VA
SSpoon9Jack KlarichNew Member Introduct...Hello from VA
SSpoon9GorillaNew Member Introduct...Hello from VA
SSpoon9SSpoonNew Member Introduct...Hello from VA
Likes Likes:  0
Results 1 to 6 of 6
Thread: VTX head light adjustment
    250+ Posts mtn rider's Avatar
    Apr 2011
    Pigeon Forge TN USA
    Default VTX head light adjustment
    After adding a 6 degree rake on my 1800 VTX it appears Im out of room to adjust the head light down far enough. Any suggestions. Thanks
    300+ Posts Smoken'JOE's Avatar
    Oct 2009
    Racine, Wis
    Default Re: VTX head light adjustment
    Quote Originally Posted by mtn rider View Post
    Are you adjusting the whole light or just the 2 front screws? I was able to adjust mine after adding rake with the adjusting screws.
    Apr 2011
    Pigeon Forge TN USA
    Thanks Joe, I adjusted both the head lite bucket and the 2 adjusting screws on the side of the bucket and was still high. After much thought I went out to my shop and cut 2 spacers on a 45 degree angle from 1/4 inch to nothing then placed them under the mounting bracket tightened them down and was then with in the limits of the adjusting screws on the side of the bucket. As they say "necassity is the mother of all inventions" lol
    Oct 2009
    Racine, Wis
    Smart move. Wonder why the difference in bikes.
    Apr 2011
    Pigeon Forge TN USA
    Thanks again for your input .
  6. #6
    Contributing Member REOFL's Avatar
    Aug 2010
    Orlando, Florida, USA
    Had the same problem with my vtx1800f3, took the light assembly out (not to hard just need some patience) removed the spring in the adjusting bolt (it was fully compressed for height adjustment and pointing to low got stopped several times by the "local" as the light was not very visible down teh road unless it was on high beam, so I just and cut off about 1/3 of teh spring and put it back together, gave me much more adjustment.
  1. Low Beam Head light Adjustment
    By Doc7402 in forum Stallion Trikes
    Last Post: 08-18-2013, 05:26 PM
  2. Running Light Adjustment
    By gjanes in forum Honda Trikes
    Last Post: 03-22-2012, 10:38 PM
  3. Head Light Bulbs
    By CASALUV in forum Honda Trikes
    Last Post: 02-14-2012, 12:01 PM
  4. Replace head light
    By MathRetired in forum Stallion Trikes
    Last Post: 09-30-2011, 03:23 PM
  5. Head Light Warning Buzzer
    By Mattel in forum Stallion Trikes
    Last Post: 08-10-2011, 03:30 PM
