Phu Cat3cScjhbGeneral DiscussionIs there a TV commercial
Phu Cat3trike ladyGeneral DiscussionIs there a TV commercial
Phu Cat3Phu CatGeneral DiscussionIs there a TV commercial
Likes Likes:  8
Thanks Thanks:  3
Page 2 of 2 FirstFirst 1 2
Results 21 to 31 of 31
Thread: What fuel? Anyone ever use Aviation fuel?
  1. #21
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Default Old thread with good info
    Read post # 11
  2. #22
    I don't use aviation fuel and the reason is I can hardly get enough of that for my flying car let alone for the motorcycle 📞🙄
  3. #23
    400+ Posts Retired Army's Avatar
    Peru, IN USA
    If flying the motorcycle is desired, lift generating devices and a pilots license will be required. This is the law of physics and the land.
  4. #24
    Sep 2016
    Springfield, Mass. USA
    Stable works for me. I also put it in my Gasoline can, in the garage that is used for lawnmower also...1/4 the price also
  5. #25
    650+ Posts
    Mar 2018
    Winston Salem ,NC
    Another example of people thinking they know more about that motor than the engineers that designed it.The recommend fuel is right in your HD owners manual. You don't have a high performance race motor and never will.These motors are designed to run off the rot gut pump swill that passes for gasoline these days.As far as Stabil-nope.I use Seafoam and lately in my Harleys, Lucas Ethanol Treatment.No advantage to using race gas,avgas.Try some JP4.Post pics.
  7. #26
    I use Sea Foam and Marvel Mystery oil in my gas
    Here in Fl I ride year round so Stabil is not needed
    I can run 90 octane Ethanol free gas with out ping
    My guess is the knock sensors adjust the timing for lower octane fuel
  8. #27
    2250+ Posts
    Ocala, Florida
    ​Wow, lots of opinions about high octane gaso. Don't know where you folks got your info but a great deal of it must be "hearsay". In the refinery I worked in, all high octane gaso. comes from the alkylation still in the refinery, so there's NOT a lot more refining. In fact, the alkylation still is the end of the line. Nor does high octane gaso, burn faster, slower, hotter, cooler or cleaner. It burns the same as every other gaso. except it resists knocking to a greater degree. The reason it burns the same as every other gaso is because it must meet the same distillation lab requirements to be labeled gaso.
    PC
    Beware of liberals posing as Americans.
  9. #28
    2250+ Posts
    Ocala, Florida
    It won't hurt anything to run high octane in your bike, or even your weed eater or lawn mower. It's just way more expensive.
    PC
  10. #29
    50+ Posts MikePerrone's Avatar
    May 2017
    Las Cruces, NM
    Default aviation fuel
    I remember when I was in the Navy I was in a squadron of T-28's (old turboprop planes) we had a guy that was broke and decided he would just sneek out and drain some fuel from one of the wing tanks, since he had a hot date. well he started the truck fine but after about 15 minutes the block was glowing red, to make matters worse he decided the "smart" thing to do was throw water on it, you could have probably hear that block crack a block away. Point of the story is...I don't recommend using aircraft fuel unless you are putting it in a airplane.
    Just my 2 cents
  11. #30
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    It’s an old thread , but read all of Phu Cats posts . It will answer most questions on octane ect .
  12. #31
    The reason for different octane ratings has a lot to do with the compression ratio of an engine . The higher the compression ratio of an engine the higher the octane is called for to stop pre ignition (Knock ) using lower octane in a high compression engine the air fuel mixture will ignite before a full compression stroke…All modern engines now come equipped with knock sensors to compensate for a Lower Octane it’s not 100% cure for the occasional low octane that might’ve been used by accident or by other circumstances..So in essence Lower Octane fuel will ignite sooner than high octane fuel during a compression stroke..
    In the bygone days if you use low octane gas in a hi compression engine and accelerated hard up a grade it sounded like you were dropping marbles into a tin coffee can..
  1. Fuel Indicator
    By Paul_Trike in forum Honda Trikes
    Last Post: 09-24-2012, 11:37 AM
  2. Fuel Pump
    By bigjoey38 in forum VW Powered Trikes
    Last Post: 06-12-2012, 12:55 PM
  3. Fuel Pac vs TTS
    By VaThumper in forum Harley Trike Conversions
    Last Post: 02-26-2012, 04:15 AM
  4. fuel
    By ronchi in forum General Discussion
    Last Post: 12-30-2011, 08:30 AM
  5. CSC aux fuel tank and MPG
    By Southern Man in forum California Sidecar Trikes
    Owners Forum
    Last Post: 11-14-2011, 09:25 PM
