Results 1 to 6 of 6
Thread: Spark plug gap
    150+ Posts geraldlanc's Avatar
    austin tx usa
    Default Spark plug gap
    The Honda book says gap from 039 to 043, so what effect does that range have on performance?
    Gerald
    300+ Posts
    Mar 2011
    Tucson, AZ USA
    Default Re: Spark plug gap
    Most manufacturer's will give a 5 point gap spread to choose from that they feel is acceptable for your model's application. The wider the spark plug gap, the more power required by the coil for the spark to jump the gap, the narrower the gap, the less power required to jump the gap.
    Under normal stock conditions, my own rule-of-thumb is to choose the gap right in the middle of the acceptable range.......in this case, for example, I'd probably go with .041.
    If mods were done that increased the compression ratio, which also makes the compressed mixture denser, I'd go with the narrower gap of .039 as higher compression (denser compressed mixture) makes it harder for the spark to jump the gap, so one wants a narrower gap.
    1000+ Posts Shimpy's Avatar
    Nov 2011
    The Villages, Florida
    Quote Originally Posted by geraldlanc View Post
    Gerald
    I doubt any. Everything manufactured has a tolerance. On the gap they are giving you a .oo4 tolerance (4 thousandth of an inch) because 1. it is not that critical, and 2. nobody can set gaps with feeler guages and get it down to a precision tolerance (.001 or less)
    I set mine to the low limit or .039. The reason I do this is because after many miles the gap seems to open due to wear of the electrode and moves towards the high limit keeping it in tolerance.
    LES
    Prowler # 67
    Iron Butt #33529
    U.S. Naval Cryptologic Veterans Ass'n
    Not sure if I have free time or I just forgot everything I was suppose to do.
    Retired and highly recommend it.
    austin tx usa
    Shimpy, what is an "iron butt" and how do you get to be one?
    Gerald
    Nov 2011
    Gerald
    The Iron Butt Association is made up of riders that like long distance indurance riding. The minimum qualifying ride is 1000 miles in a day that are witnessed and verified. There are many other rides that are very grueling. Check out their web site. IBA - World's Toughest Motorcycle Riders
    LES
    Prowler # 67
    Iron Butt #33529
    2250+ Posts
    Ocala, Florida
    ​To answer the original question of whether or not gap has any effect on performance, the answer is no. The reason is, the milli micro second the spark starts to jump the gap to initialize the flame front, the spark plug is thereafter out of the picture.
    PC
    Beware of liberals posing as Americans.
  1. Change 5-round plug-in to 4-flat plug in for trailer
    By BinIdaho in forum Harley Trike Conversions
    Last Post: 02-26-2013, 11:42 PM
  2. spark plugs
    By DJS in forum Honda Trikes
    Last Post: 06-03-2012, 04:26 PM
  3. spark plugs
    By geraldlanc in forum General Discussion
    Last Post: 03-24-2012, 09:03 AM
  4. Spark Plugs
    By drumdoctor in forum Home Built Trikes
    Last Post: 09-21-2011, 03:19 PM
  5. Spark plugs
    By John Luciano in forum General Discussion
    Last Post: 07-29-2010, 06:41 AM
