Results 1 to 8 of 8
Thread: tire trouble......maybe not
    750+ Posts tom w's Avatar
    Sep 2013
    poplar bluff mo
    Default tire trouble......maybe not
    I had to go in the hospital and have a stint put in (again) and didn't ride for a week or 2 . we were getting ready for a ride sunday (finally) and I went out to check the air in the trike tires. needed a couple of pounds in the right rear and about 5 in the front.
    when I checked the front one and took the gauge off , all of the air came out. couldn,t get it to stop. I took the valve core out and found a small balance bead stuck in the bottom of the valve core.
    I have now added a valve core tool to my tool kit. glad I was home when this happened !
    Jun 2010
    Coram, NY USA
    Default Re: tire trouble......maybe not
    Might want to add a small electric air pump also. I always carry one.
    Sep 2013
    poplar bluff mo
    have one in my truck that is going to find a new home in my trike trunk.
    Mar 2011
    mountain home,ar. USA
    Yep, I made the same mistake on my ST1300. New procedure.
    1. Carry air compressor
    2. Turn wheel so valve stem is between 4 and 8 o'clock.
    3. Give a quick shot of air BEFORE checking pressure to remove any beads stuck in valve core.
    150+ Posts
    Oct 2013
    Harrison,Ohio
    Quote Originally Posted by mhgoldwing View Post
    Like that tip!
    Sep 2013
    poplar bluff mo
    at least I learned it at home in a garage with the tools to fix it.
    800+ Posts
    Aug 2011
    Evansville, IN
    Quote Originally Posted by tom w View Post
    I don't know what brand of balance beads you use, but Dyna Beads sells a Filtered Valve Core, I guess to prevent what happened to you.
    800+ Posts Big Juice's Avatar
    Nov 2013
    Hot Springs Village, Arkansas USA
    I almost went to the beads, but decided I liked the Ride On product instead. So far, no problems.
    ​O J Miles - now riding "Lucille", a 2017 Spyder F3-Ltd. Roadster.
    When 2 wheels aren't enough and 4 are too many.
    Ahhhh, a hot cup of coffee and a good cigar, after a good ride.......
  1. Trouble at the Gun Shop
    By americanbadass in forum The Gun Enthusiast
    Last Post: 08-17-2013, 01:57 AM
  2. Engine trouble in the rain
    By Tubal Cain in forum Honda Trikes
    Last Post: 08-16-2013, 09:59 AM
  3. Speedo trouble.
    By Biker-Dave in forum Harley Trike Conversions
    Last Post: 07-07-2012, 06:55 PM
