Likes Likes:  8
Results 1 to 20 of 20
Thread: up grade clutch?
    950+ Posts
    Oct 2014
    Rochester, NH, USA
    Default up grade clutch?
    Have any RSV owners upgraded your clutch since your conversion? Mine seems to slip some when I take off. Maybe it's me still getting use to the extra weight of the trike.
    350+ Posts Jonesy's Avatar
    Apr 2010
    Springfield.
    over on venturerider.org theres someone who sells the kit to do it. easy to do, less than a hr. if I remember right.
    200+ Posts dbruce56's Avatar
    Nov 2014
    Salem, Al
    You may only need a better spring kit. From what I've seen and heard from various Yamaha sites, the usual culprit for clutch slippage is the clutch springs. Barnett makes a great spring kit that I've seen recommended in every forum that I frequent. J & P Cycles carries it for about $161. Have seen it on amazon for as low as $135. Hope this helps you.
    Apr 2010
    Springfield.
    the venturerider.org guy is skydoc17, his kits are $95, this is what I used on mine.
    200+ Posts alwrmcusn's Avatar
    Mar 2013
    Rockwood, TN
    I had the Barnett clutch installed after I had my RSV triked. Easy to do.
    FRA Branch 294 Crossville, TN
    PGR Rider
    80+ Posts Condor's Avatar
    Sep 2014
    Carmichael, CA, USA
    Before tossing money around like you owned a bank, the #1 reason a clutch slips is dirty fluid and a plugged expansion hole at the base of the reserve from crystals formed in the DOT. Bleed the clutch and make sure the hole is clear first before pulling out your wallet...
    300+ Posts Cougar's Avatar
    Mar 2009
    Near-Iowa City,Iowa
    Dot 3 or 4 ?
    950+ Posts
    Oct 2014
    Rochester, NH, USA
    for those who have replaced the clutch, is this a good deal?
    $268.44 (free shipping) for the following:
    Barnett Clutch Spring Conversion Kit #511-90-10002 ($134.71)
    Barnett Clutch Plate Kit #306-90-20082 ($121.44)
    Yamaha Crankcase Cover Gasket #5PX-15451-00-00 ($12.29)
    350+ Posts
    Aug 2009
    Wayne, Mi USA
    Barnett clutch systems may be good but expensive IMHO. I've use SkyDoc's system on both the 05 and 09 RSV's after converting to a trike. A much needed improvement over the stock system. Way cheaper and solves the problem with weak slipping discs on a heavier trike conversion. http://www.venturerider.org/forum/ph...ade-kit&cat=17
    Larry
    950+ Posts
    Oct 2014
    Rochester, NH, USA
    Quote Originally Posted by Carbon_One View Post
    Larry
    Just got SkyDoc's kit in the mail today!! Now I need to find someone nearby who has done this before. I know just enough to get me in trouble..lol
    350+ Posts
    Aug 2009
    Wayne, Mi USA
    Quote Originally Posted by Dennisgar View Post
    Good choice. Hopefully there's someone nearby to lend a hand if needed.
    Sep 2015
    MONTVALE
    Default clutch upgrade through skydoc_17
    how do you contact him,i have tried emailing through venture site but never get a notice that my email has been sent and trying to post says i dont have proper authourity or admin blocked me (which i know isnt the case)
    100+ Posts steamer's Avatar
    Jun 2011
    romulus ny,usa
    Quote Originally Posted by gogi View Post
    When you are in venture riders, click on classifieds then scroll down to members vendors. You will find skydoc17, click on his name and send him a pm.
    Sep 2015
    MONTVALE
    Default skydoc
    [as i said the site,even though i'm a member will not allow me to send pm or buy it.i need to contact him to find out exactly what i should order
    950+ Posts
    Oct 2014
    Rochester, NH, USA
    if you didn't pay the $12 then you will not be able to do a few things on the Venture Riders site. If you did pay, then I would contact one of the site administrators and ask for assistance.
    Jun 2011
    romulus ny,usa
    You are not listed as a paid member. If you did pay then you need to contact freebird to get this straightened out. It is well worth the $12.00 if you want the best info and advice on the RSV. Also a bunch of great people, just like here.
    Sep 2015
    MONTVALE
    Default Sky_doc17
    Yeah just found that,they should just say that was why i couldnt post it. As i was a member didnt realize it lapsed.
    950+ Posts
    Oct 2014
    Rochester, NH, USA
    Hopefully you will get back on the site and contact SkyDoc17. I'm glad I bought his kit instead of the other! Also, as Steamer said, great bunch of folks on VR. I had never met a single person and the first time I did two of the guys changed my clutch out while 7 others supervised. Doesn't get better then that!!! LOL
  19. #19
    Jun 2016
    Trail, BC Canada
    Since 1983 I have rode Yamaha Ventures, Venture Royale's and now RSMV. While touring weighed us at truck scale, just over 1450Lbs. I know, too heavy but with everything full and a tank bag.
    Just having a Hannigan kits installed next week. Bike 860lbs, kit 320 lbs, us 320lbs Total about 1500lbs. Why would trike kit be harder on clutch than 2 wheel when weight is very close. In 8 bikes never touched clutch. Actually the only problem is on the newer models, rear air shock. Every one failed.
    Robby
  20. #20
    450+ Posts bongobobny's Avatar
    May 2013
    Arcade, NY USA
    Quote Originally Posted by Robby View Post
    Robby
    Well, actually Robby, do the math!!If you divide 320 lbs by 860 (percent increase in weight) you come up with an astounding 37.2% INCREASE!!! Unfortunately with the 2nd Gen's the clutch is a weak point to begin with, and you are putting almost 40% More load on it!! After triking my '09 with the Hannigan, by the end of the season mine was slipping considerably!
    The following spring at Freebird's Maintenance Day we replaced the stock clutch half plate with the optional Yamaha full plate, I replaced all the friction discs and the steel discs as well as they were really blue'd, and installed the PCW heavy duty spring. That was in 2012 and I haven't had a single issue since!! However if I do have to replace again I am going with the complete Barnett setup.
  1. Performance up grade.
    By rhino 2 in forum Harley Tri Glide
    Last Post: 04-17-2015, 02:56 PM
  2. Gas grade
    By bluesman in forum Harley Trike Conversions
    Last Post: 09-18-2013, 08:35 PM
  3. New Build Hydraulic Clutch/Brake Clutch Pedal Fabrication
    By usnavy8084 in forum Home Built Trikes
    Last Post: 10-21-2012, 08:18 AM
  4. Start of a 2011 Trike up grade
    By Reloader53 in forum Harley Tri Glide
    Last Post: 12-26-2011, 05:57 AM
  5. clutch
    By sprayman in forum General Discussion
    Last Post: 05-29-2010, 08:50 PM
