SSpoon5trike ladyNew Member Introduct...Hello from VA
gfaltersack1gfaltersackHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon5SullyNew Member Introduct...Hello from VA
SSpoon5Jack KlarichNew Member Introduct...Hello from VA
SSpoon5GorillaNew Member Introduct...Hello from VA
SSpoon5SSpoonNew Member Introduct...Hello from VA
Likes Likes:  2
Results 1 to 3 of 3
Thread: Altitude issues.... Why?
    100+ Posts
    Dec 2013
    Omaha
    Question Altitude issues.... Why?
    We are on a trip thru Rapid City, SD the Coy, WY and Yellowstone, etc.... I have gone over the mountains in CO before and have had similar issues as today in the Mountains. When waaay up there my clutch doesn't want to disengage. It usually disengages very early, but when up there it is very near the bars before I feel any resistance in the handle, and it is difficult to shift. The same happened to my rear brake only, the front brake was not affected at all. At one point, I had NO rear brake until I pumped it a few times, then it was fine. My buddy was on his 08 HD and had no affects from the altitude.
    Please understand that I know it is caused by the altitude and differing pressures in the air, but....
    How does it / WHY does it do it to CLOSED hydrolic systems? (All of mine have been flushed / new within the last couple of years and are at the appropriate levels.)
    Why aren't my buddy's HD hydrolic systems being affected - like my front brake?
    150+ Posts
    Oct 2011
    West Bloomfield, Mi
    I can tell you from similar experience that your clutch &amp; brake fluids have excessive moisture in them and need to be changed. I had the same issue on a trip over Beartooth, flushing with new fluid solved the problem. &nbsp;Change the fluids every season, cheap, easy insurance.<br />
    <br />
    Quote Originally Posted by Craigatcsi View Post
    We are on a trip thru Rapid City, SD the Coy, WY and Yellowstone, etc.... I have gone over the mountains in CO before and have had similar issues as today in the Mountains. When waaay up there my clutch doesn&#39;t want to disengage. It usually disengages very early, but when up there it is very near the bars before I feel any resistance in the handle, and it is difficult to shift. The same happened to my rear brake only, the front brake was not affected at all. At one point, I had NO rear brake until I pumped it a few times, then it was fine. My buddy was on his 08 HD and had no affects from the altitude. Please understand that I know it is caused by the altitude and differing pressures in the air, but.... How does it / WHY does it do it to CLOSED hydrolic systems? (All of mine have been flushed / new within the last couple of years and are at the appropriate levels.) Why aren&#39;t my buddy&#39;s HD hydrolic systems being affected - like my front brake?
    Gone But Not Forgotten
    Tech Contributor
    Lee H. Mann's Avatar
    Apr 2011
    Martinsburg, WV
    Decreased pressure on the outside increases pressure differential on the inside.
    Make sure your clutch reservoir is not over-full.
    Jim Murphy
    Iron Butt Rider 2001
  1. GPS Issues With 2014 Tri
    By The_Bob in forum Harley Tri Glide
    Last Post: 08-27-2015, 08:26 AM
  2. Radio Issues
    By Bonedaddy in forum Harley Tri Glide
    Last Post: 11-16-2014, 02:55 PM
  3. Any clutch issues?
    By motoadvrider in forum BMW Trikes
    Last Post: 02-24-2013, 07:19 AM
  4. High Altitude ECM chip
    By GoSlo in forum Harley Trike Conversions
    Last Post: 12-14-2012, 05:25 AM
  5. Warranty issues
    By tfdeputydawg in forum General Discussion
    Last Post: 02-04-2011, 05:06 PM
