Likes Likes:  1
Results 1 to 4 of 4
Thread: Maybe purchasing a "Motor Trike" 1800 2006 Honda goldwing trike
    450+ Posts tbear's Avatar
    Sep 2013
    Carleton, Michigan
    Default Maybe purchasing a "Motor Trike" 1800 2006 Honda goldwing trike
    Anybody had a problem with Motortrike conversions?
    TBEAR
    2010 Triglide Harley Davidson
    V&H Exhaust,True Duals, Big Sucker Ac,,557 S&S Cam,SE Compensator 2014, oil cooler,EBC r.brakes,Progressive air-shocks,Floorboard extensions,rear fender bras, Dynoed,krome-werks 2+2 bars, and a sheep wool butt protector....
    950+ Posts
    Jun 2013
    DFW, Texas
    Had a 2006 MT conversion. Be sure to check if the drive shaft is original or a replacement. Some of the u-joints used back then didn't stand up well.
    300+ Posts Rev Ray's Avatar
    Dec 2010
    Keeter,Tx.U.S.A.
    we ran a 2002 motortrike mustang rear axel many many miles,now ride 2014 motortrike IRS, no problems with either one. I think they build a quality product.
    600+ Posts keepinon's Avatar
    Dec 2011
    New Caney, Tx
    I had a Valkyrie with the MT straight axle conversion, the only problem I had was self induced. I twisted a couple of drive shafts by hot-rodding... then MT came out with their new drive shaft and I had no more problems. I now have an '07-1800 MT Adventure IRS, ridden 20k miles in the last year with no issues.
    MT made two styles of conversions for the 1800, SA & IRS. You'll just have to look to see which it is. If you remove the right side cover & look at the front u-joint, if it's green it's the new heavier duty style.
  1. Replies: 3
    Last Post: 04-03-2013, 03:11 AM
  2. Motor Trike rear pulley "flange"
    By sherry2365 in forum New Member Introductions
    Last Post: 08-26-2010, 12:19 PM
