Likes Likes:  2
Results 1 to 5 of 5
Thread: Rookie Bonehead Move Today
    250+ Posts rhino65's Avatar
    Aug 2016
    Atwood, Illinois United States
    Default Rookie Bonehead Move Today
    Only had my trike for about 6 weeks now. Never had a cruise on bike till now either. So today on my New Years Day ride I looked down at speedo & saw my rev light on going down highway. Not sure when I pushed it on during ride. Got into town and used rev. It still worked as normal. What kind of damage did it do or not do?
    2002 GL1800 with CSC trike kit
    May 2011
    San Angelo
    Quote Originally Posted by rhino65 View Post
    I believe you are good Brian..... You can't be the first to do that and I've never heard of any damage due to accidental switch activation. I thought we got a blinking reverse light on the dash to alert in that situation but have never tried to see if it actually would blink... Here's hoping I guess correctly...
    2015 GL1800/Roadsmith HTS1800
    Aug 2016
    Quote Originally Posted by Gold Rush View Post
    It may have been flashing. I turned it off when I saw it probably quicker than it could have blinked. Lol. I tried it rev when I got home and everything seemed good
    Mar 2011
    mountain home,ar. USA
    there are several safety mechanisms in place and I believe on of them is being in neutral. Although the light came on I doubt anything happened and you should be good.
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    No harm done. Reverse is mechanically locked out of engagement while in any gear.
    To test it for yourself ... at idle shift into any gear and push the "Rev" switch to the on position. You will find that reverse will not function. The same mechanism locks out shifting once reverse is engaged. To test that ... at idle and in neutral, push the "Rev" switch to the on position. Then try to shift into gear. You will find that reverse operates but not able to shift.
  1. Next rookie question, regarding overheating
    By dartref in forum Harley Tri Glide
    Last Post: 06-10-2016, 10:59 PM
  2. Stupid rookie mistake
    By Phu Cat in forum General Discussion
    Last Post: 05-22-2016, 09:15 PM
  3. Rookie from Pa.
    By 67bug in forum New Member Introductions
    Last Post: 06-14-2013, 11:54 AM
  4. Rookie triker from Georgetown TX
    By travler in forum New Member Introductions
    Last Post: 06-13-2013, 08:09 AM
  5. Rookie Querstions on the Triglide
    By Guiderider in forum Harley Tri Glide
    Last Post: 07-24-2009, 09:46 AM
