LD-Ordie6trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie6SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Likes Likes:  1
Results 1 to 4 of 4
Thread: Need some help with stamped numbers on case
    30+ Posts
    Aug 2016
    Fort Mill, South Carolina, United States
    Default Need some help with stamped numbers on case
    I have a type 3 case on my trike while looking at it i found the number 327 stamped in both sides at the flywheel end. What do the numbers mean? Are they from a machine shop?
    Any help would be great.
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    I will check around
    But
    I always was under the impression that those numbers were there from the factory. Was to keep case halves together. Can not mix and match halves.
    The numbers that identify what the engine is are on the gen stand pad.
    30+ Posts
    Aug 2016
    I will check around
    But
    Thank you.
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    I will check around
    But
    I believe you are correct Rex. I think that is all them numbers indicate.
  1. More part numbers - just in case
    By TnTrikeRider in forum Stallion Trikes
    Last Post: 07-06-2016, 05:29 PM
  2. V.I.N. Numbers
    By Rickety in forum Home Built Trikes
    Last Post: 08-25-2015, 11:42 AM
  3. just in case
    By homer in forum Harley Trike Conversions
    Last Post: 06-11-2010, 01:13 AM
  4. just in case
    Last Post: 05-31-2010, 02:20 PM
