ADSavarese8ol' schoolNew Member Introduct...New member from FL
ADSavarese8GorillaNew Member Introduct...New member from FL
ADSavarese8Marc HNew Member Introduct...New member from FL
ADSavarese8ADSavareseNew Member Introduct...New member from FL
ADSavarese8Phu CatNew Member Introduct...New member from FL
ADSavarese8trike ladyNew Member Introduct...New member from FL
ADSavarese8Uncle FesterNew Member Introduct...New member from FL
ADSavarese8rhino 2New Member Introduct...New member from FL
Likes Likes:  6
Results 1 to 9 of 9
Thread: No headlights
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Default No headlights
    2003 GL1800 has no headlights (high or low beam). When put in reverse, the low beam lights come on and also the side stand light.
    The problem was the starter switch. The headlamp bypass that is actuated by he starter button wasn't working. I hit the switch several times Vigorously with my thumb and the lights started working and the side stand light went out.
    Dreaded sticky buttons in the dirty switch. Just thought I would pass it along .....
    Jim Murphy
    Iron Butt Rider 2001
    400+ Posts
    Oct 2015
    carbon, texas
    Thank you Jim. I've had trouble with my kill switch before. It was almost like you could look at it and would kill my bike. Someone in the know said give it a workout and see what happens. I guess it cleaned the contacts because it started working properly.
    Sep 2016
    Springfield, Mass. USA
    Good information to know.................thank you
    JustWings.com
    GoldWingrGreg's Avatar
    May 2016
    Zephyrhills, FL, USA
    Unfortunately, the best fix is to replace the switch assembly. For anyone wanting to repair their kill switch, I have these kits in stock from the link below. I have no idea what all years the kit fits.
    http://www.justwings.com/uploads/SB-...top_Switch.pdf
    First thing I did when I bought Tweety was to take all the switches apart and clean them with contact cleaner.
    JustWings.com
    May 2016
    Once a switch is clean, this product has worked well for me.
    https://www.radioshack.com/products/...-and-lubricant
    Meme Master
    Jan 2014
    Farmington, NH USA
    Quote Originally Posted by GoldWingrGreg View Post
    Good tip Greg
    Is there any other manufacturer that offers this product?
    I ask as R/S stores have all but disappeared near me, & it shows the product is currently unavailable on line to order...
    2750+ Posts Rosy's Avatar
    Jan 2012
    Dover, NH USA
    My cruise control switch was sticking, so I sprayed it with silicone and it works great. Took the little tube and sprayed it so it went to the back of the switch.
    Had to clean the front of the switch because it was very slippery and my thumb kept sliding off of it! LOL
    Rosy
    JustWings.com
    May 2016
    Good tip Greg
    What's good about that stuff is that it foams, and it's not a silicone lube. Unfortunately, it's only ever been sold from their ground stores. You might try a good auto parts store for something similar, or google and look for electronic supply stores in your area ... they might have something similar. Since the beginning of my time working on GL1800s, it's the only thing I've ever used, possibly someone else might share what they use.
  1. Headlights
    By Dragon in forum Stallion Trikes
    Last Post: 03-19-2017, 06:55 PM
  2. Headlights after triking
    By mgwtrike in forum Honda Trikes
    Last Post: 10-02-2015, 09:20 AM
  3. Headlights
    By rocket1lf in forum Stallion Trikes
    Last Post: 04-08-2015, 06:58 PM
  4. headlights
    By roscoe 07 in forum Honda Trikes
    Last Post: 03-02-2012, 07:10 AM
  5. LED Headlights
    By atwoodka in forum Harley Trike Conversions
    Last Post: 09-13-2010, 12:09 PM
