SSpoon2GorillaNew Member Introduct...Hello from VA
SSpoon2SSpoonNew Member Introduct...Hello from VA
Likes Likes:  6
Results 1 to 8 of 8
Thread: Clutch Cable set up?
    100+ Posts sonny8l3's Avatar
    Oct 2014
    Livingston (Colyell ), Louisiana, USA
    Default Clutch Cable set up?
Size:  192.7 KBName:  Resized_20170623_101329.jpeg
    Hello, What kind of set up are others using for your clutch cables? If my 2 pictures loaded, this is what I have. On the motor end, the cable is cut and rejoined with a barrel cable clamp. The U bolt clamp is there as extra comfort for me. This is the 4 set up I've tried and it seems to be working so far. But I'm interested in what others are doing, Thanks for your time.
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    I have seen lots of them cable clamped together like that. Seems to work. I would not do it with a heavy hot rod clutch.
    As long as the Bowden tube is set up right things should be good.
    Oct 2014
    Hello, After breaking 3 cables in 2 years my mechanic figured out how to modify my idea into something that worked. But I'm wondering what others are doing to make the cable work in a distance shorter than the factory cable. Thanks for your time
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    The most common thing to use is the dune buggy hydraulic set up.
    Oct 2014
    I saw one of those on a trike at my mechanics. It is a clean set up and I like it a lot. But, I have just about got everything set up so the dog and I can travel a bit. With my serious lack of mechanical ability I decided that I can fix a broken cable on the side of the road easier than I could work on a hydaulic system. Also, with a real limited budget, I can carry a spare cable a lot cheaper. I'm wondering if I could make a cable with the right ends and to length. It would make a road side repair much easier. Thanks for your time
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    Yep, pretty much what I'm running.
    Meme Master
    Jan 2014
    Farmington, NH USA
    Hard to believe nobody makes a "shortened" clutch cable
    As others have noted above, the hydraulic setup is really the way to go for trouble free operation...
    VW Tech Expert Loner's Avatar
    Aug 2010
    Harvest, AL USA
    If you want to make up a spare you might consider going to a local builder's supply and picking up a 'spindle loop' (see image below) of appropriate size for the pedal end of your clutch cable. With a good swage fitting to secure the cut cable you can make a clean unit that will last. If available, the extra bit of cost for stainless parts will be worth it.
  1. 09 clutch cable length
    By stroker 23 in forum Harley Tri Glide
    Last Post: 09-08-2015, 08:17 PM
  2. New Build Hydraulic Clutch/Brake Clutch Pedal Fabrication
    By usnavy8084 in forum Home Built Trikes
    Last Post: 10-21-2012, 08:18 AM
  3. clutch cable shorting
    By greg will in forum VW Powered Trikes
    Last Post: 03-09-2012, 11:07 AM
  4. Question about clutch cable routing
    By JohnC in forum Harley Trike Conversions
    Last Post: 01-01-2012, 10:01 PM
  5. Clutch Cover / Cable Leak
    By trikes4ever in forum Harley Trike Conversions
    Last Post: 11-21-2010, 06:20 PM
