LD-Ordie6trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie6SullyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie6LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
Results 1 to 4 of 4
Thread: Brake Pedal Extension
    Lost In The 50's rmrc51's Avatar
    Feb 2009
    Palmyra, Virginia
    Question Brake Pedal Extension
    Do any of you know of an extension that I can put on the brake pedal of my Valkyrie that would extend the surface out away from the body of the bike?
    The reason I ask is that my feet, when sitting, stick out at least a 45 degree angle and its a PIA to try and straighten my foot to catch the brake pedal. I barely touch the extreme right of the foot brake now and that's with the Kurykan cover addition on it.
    Thanks in advance for any suggestions or solutions.
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Default Re: Brake Pedal Extension
    Rich-
    Show Chrome makes a wide slip-on pedal cover that should do the trick for you. Its wider and taller and works well. See part number: 1-328 - Brake Pedal Cover. It can be ordered here:Scoot Works (see last item at bottom of page)
    Contributing Member wingking51's Avatar
    Dec 2009
    Friedens, PA
    You might check out wingstuff.com . They have a brake pedal extension that measures 4 1/2" w x 1 15/16" d made from billet aluminum and is chrome plated. It is for GL1800 and bikes with a large pedal.
    Feb 2009
    Palmyra, Virginia
    Thumbs up Re: Brake Pedal Extension
    Thanks guys. I was mistaken when I said I had a Kuryakan cover. It's the Show Chrome one the Bazooka posted.
    I will check the one Wingking51 mentioned on Wingstuff.com.
    Thanks again.
  1. Extended rear brake pedal
    By MMH in forum General Discussion
    Last Post: 10-16-2013, 03:34 PM
  2. brake pedal disengaed
    By MathRetired in forum Stallion Trikes
    Last Post: 08-24-2012, 03:40 PM
  3. Over size brake pedal
    By felixpirozzi in forum Honda Trikes
    Last Post: 12-08-2011, 09:54 AM
  4. Stallion brake pedal.
    By DEIC in forum Stallion Trikes
    Last Post: 11-13-2009, 07:34 PM
  5. moving a brake pedal plus other
    By acmeactor in forum General Discussion
    Last Post: 11-05-2009, 04:55 PM
