Likes Likes:  2
Results 1 to 4 of 4
Thread: 2002 Roadhawk trike body tilt.
    Aug 2017
    copan ok washington
    Default 2002 Roadhawk trike body tilt.
    Hello all, Does anyone know of a way to make the body of the roadhawk trike tilt up for eazy access to the motor area, now I have to access it from underneath or take wheels off, I would think there was a better way. Thks.
    450+ Posts
    Mar 2018
    Fernley
    Good day to everyone, I do hear that, it would be awesome to have a body that lifted up with a push of a button.
    No real help from me, never done it, but you need a double hinge point for stableness on a large body and a smaller light weight body might work with a single center hinge.
    One can make it like door hinges, or brackets and pinned bushings would do the trick.
    I do hope you the best with this project.
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    I thought I had seen this done before.
    But I can not find it now.
    No real advice other than whatever you do it will be all hand made by you.
    May 2017
    Sun City, Arizona
    Default I wush
    I have had the body off mine a dozen time in the last six months getting the engine swap done from VW engine to a water cooled GM ecotec 2.4l. I can't imagine how you could accomplish a tilt up without spending a lot of engineering time and a boat load of dollars and still have a safe stable machine. It's not that hard to pull the main body. I use and overhead electric winch and straps to be able to do it by my self. Otherwise it's a two person job.
  1. 2002 Trike Shop Roadhawk
    By starrider1946 in forum VW Powered Trikes
    Last Post: 09-15-2018, 06:34 AM
  2. 2002 Trike Shop Roadhawk super beetle wheel cylinder upgrade
    Last Post: 08-23-2017, 05:18 PM
  3. 2002 Roadhawk questions
    Last Post: 05-24-2016, 11:07 AM
  4. 2002 Roadhawk handle bars
    Last Post: 07-08-2015, 01:06 PM
  5. Tilt Bed Trailer
    By sporter in forum Trailers / Campers
    Last Post: 12-01-2011, 09:03 PM
