Likes Likes:  1
Results 1 to 6 of 6
Thread: Building a Replacement VW trike from scratch
    Jun 2018
    Rising Sun
    Default Building a Replacement VW trike from scratch
    Built one back in the 70's,BUT, marraige,a house and kids,well you know what happened
    The first one I used a "gas tank" from the beetle I cannabilized.. I cut the body,at the door frame and went from there. I see a lot of the V.W. trikes with 6 gallon gas tanks,which at the most run 180 miles til empty. I plan on using a stainless steel 15 gallon beer keg as a fuel tank. Enough of plans, what I am asking,is putting a "sending unit" in the keg and setting it "horizontal" and wondering where I can get a "filler" cap? Researched a lot of sites, but, have been hitting on ZERO. Any and all info would be greatly appreciated.
    Jerry, Welcome to Trike-Talk............
    Quote Originally Posted by JerryJ View Post
    Give Parts Geek a try.......
    Meme Master
    Jan 2014
    Farmington, NH USA
    Welcome to T/T Jerry.
    Glad you are now deciding to bet back "into" the trike scene in your build.
    I'm not aware of any specifically designed mounting kits for keg tanks, but Speedway Motors has some interesting parts for the building of hot rods and such.
    Here's a link that might help you: https://www.speedwaymotors.com/shop/...cells~6-12-516
    Good luck, and post pics as you advance your trike project to completion...
    Welcome aboard Jerry. I've seen the kegs taped on the end at the bottom and a sight type tube setup to show the fuel level. Don't know about the fill opening.
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    Look around at dune buggy parts and marine pleasure craft (ski boat, bass boat) stuff.
    I would think a lot of that stuff would useful.
    None of it a direct fit. Some fabrications required.
  1. Building a trike from scratch
    By JackSum in forum VW Powered Trikes
    Last Post: 10-05-2017, 06:49 AM
  2. Scratch on fender of rear back tire.
    By DonC in forum Harley Tri Glide
    Last Post: 11-18-2015, 09:20 AM
  3. Looking to build a V8 trike from scratch
    By BigLee263 in forum New Member Introductions
    Last Post: 08-01-2014, 10:36 AM
  4. Building a trike kit from scratch
    By junglebear in forum General Discussion
    Last Post: 09-07-2013, 08:28 PM
  5. Aussie thinking of building a trike
    By carmima in forum New Member Introductions
    Last Post: 09-24-2008, 07:12 AM
