SSpoon9Marc HNew Member Introduct...Hello from VA
SSpoon9ZammyNew Member Introduct...Hello from VA
SSpoon9Uncle FesterNew Member Introduct...Hello from VA
SSpoon9rhino 2New Member Introduct...Hello from VA
SSpoon9trike ladyNew Member Introduct...Hello from VA
SSpoon9SullyNew Member Introduct...Hello from VA
SSpoon9Jack KlarichNew Member Introduct...Hello from VA
SSpoon9GorillaNew Member Introduct...Hello from VA
SSpoon9SSpoonNew Member Introduct...Hello from VA
Likes Likes:  1
Results 1 to 3 of 3
Thread: suspension, rpm
    30+ Posts justlucky's Avatar
    Feb 2018
    northridgeville, OHIO, USA
    Default suspension, rpm
    is thier a way to put air bladder or air ride suspension on kawasaki vn900c 2008 lehman trike storm nag rear axel?
    and have you heard of anybody puting on a forward pulley from 32 to a 34 tooth for better rpm at higher speed performance?trying something to better the ride still shaky at higher speeds not wobble
    Gone But Not Forgotten
    Tech Contributor
    Lee H. Mann's Avatar
    Apr 2011
    Martinsburg, WV
    Quote Originally Posted by justlucky View Post
    I would imagine you could retro-fit an air shock in place of the original coil-over, but that would require removing the swingarm. As far as a sprocket change goes, if one is available you would have to move the rear axle forward 1/2" (might not be enough adjustment) or replace the belt with a longer one if one is available. The Storm is what it is and you might be trying to create something that will ultimately be a mechanical headache.
    Jim Murphy
    Iron Butt Rider 2001
    Feb 2018
    that is what i thought? about the air ride. as far as the foward pulley having trouble getting it off. was wondering ? I have remove the housing brace linkage. do i have to remove the tires or just the alignment bolt a turn or two? to loosen up the belt to get the pulley off and on - yes and count the turns and mark placement?
    In advance A BIG THANK YOU TO YOU>>>>>.
  1. TriGlide Suspension Upgrade By Progressive Suspension
    By JohnC in forum Harley Tri Glide
    Last Post: 02-22-2012, 05:22 PM
  2. Rpm's
    By Triker Mike in forum Honda Trikes
    Last Post: 02-05-2012, 06:31 PM
  3. Reduce the engines rpm at idle...
    By pmar6004 in forum Stallion Trikes
    Last Post: 07-14-2011, 07:13 AM
  4. RPM'S with 30 tooth change
    By VaThumper in forum Harley Trike Conversions
    Last Post: 06-29-2011, 02:19 PM
  5. Which is best the Champion Independent Suspension or Solid Suspension.
    By glawrence7 in forum New Member Introductions
    Last Post: 11-24-2010, 12:00 AM
