Likes Likes:  4
Thanks Thanks:  1
Results 1 to 12 of 12
Thread: lehman parts
    May 2018
    North Ridgeville
    Default lehman parts
    I have called Lehman-Champion and two Lehman dealers and it seems Lehman does not have parts for kits made by the original Lehman company. Do the current Lehman owners still make Lehman trike kits? I find It hard to believe there are not any parts somewhere for a 2012 renegade kit.
    5750+ Posts BillR's Avatar
    Aug 2015
    Gloucester, VA
    Ronald, welcome to TrikeTalk.
    Contact Jim Murphy. His screen name on here is LEE H. MANN.
    He has some older parts available.
    His web site is listed in his profile. Hope you find what you need.
    Bill
    R I P MANDY
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Quote Originally Posted by dlbhaas View Post
    Donald, What do you need for your 2012 Renegade ??
    Jim Murphy
    Iron Butt Rider 2001
    May 2018
    North Ridgeville
    I need a rear axle for the short side,and a wheel hub. It is for a 2008 electra glide.Trike conversion is a 2012. I spoke with you last week. I will have to have a machine shop make the parts this winter.
    Martinsburg, WV
    Lots of things on my plate ... mostly info seeking.
    I will try to contact NAG and see what inventory they might have.
    Do you have an axle length from tip to tip ?
    Do you also have the picture of the broken hub ?
    Bigger Question, do you know what caused it to break ? Loose ?
    The drawings that I have are not complete and don't have the hub or axle in them.
    Jim Murphy
    May 2018
    North Ridgeville
    Axel nut was loose,not sure why it was loose. Splines on end of axle very worn. Splines in hub are worn. The part that is pressed on the axle that the bearing sets against wore down .25 of a inch. I had a .25 inch spacer made and put it all back together with loctite 660. I would feel much better replacing the parts. I was able to find the bearing.
    16500+ Posts
    ol' school's Avatar
    Sep 2015
    Mercersburg, PA
    Welcome to Trike Talk Donald! I see you have already found our resident Lehman guru! Jim is the best source to help you with your issues on your Lehman trike!
    Martinsburg, WV
    Sent an email to my contact at NAG, hope he will respond. I do have a NAG axle in hand, but I am reluctant to sell it before I have a source, or drawing, to make another one. I will contact you with whatever I find.
    Jim Murphy
    May 2018
    North Ridgeville
    I appreciate your help. Machine shops in my area are very busy right now. 2 to 3 months behind. I am very frustrated because of the response I got when I called Champion. As these units get older people will need these parts.
    May 2018
    North Ridgeville
    I know it has been a while. I am still looking for rear axle parts. Does anyone know if there is a whole new rear axel assembly that would fit my trike?
    May 2018
    North Ridgeville
    I am still looking for parts to rebuild my rear axle. Splines are all worn and play in rear end. Any help would be appreciated. I am ready to buy the whole axel assembly if there is something that will fit.
    Martinsburg, WV
    Thumbs up
    Donald,
    Call me ... use website for phone number www.mjtrikes.com
    Jim Murphy
  1. Lehman Owners Forum: Post Your Lehman Pics
    By Papa Zook in forum Lehman Trike
    Last Post: 04-03-2024, 01:14 PM
  2. Lehman Trike Parts & Info Thread
    By Lee H. Mann in forum Lehman Trike
    Last Post: 08-28-2023, 10:51 PM
  3. Testimony on using Lee H. Mann for Lehman parts!
    By camplejeune in forum Lehman Trike
    Last Post: 10-20-2018, 07:34 AM
  4. LEHMAN PARTS
    By dgrenzi in forum Lehman Trike
    Last Post: 02-23-2018, 12:11 PM
  5. Changes to the Stallion or New Aftermarket Parts?
    By Mattel in forum Stallion Trikes
    Last Post: 10-26-2008, 08:06 PM
