Results 1 to 3 of 3
Thread: Rear rotors- brakes 2012 gl1800 hts1800
    Jul 2018
    Rochester
    Default Rear rotors- brakes 2012 gl1800 hts1800
    Ok i was told that the rear rotors can only be purchased through Roadsmith. Seems they buy blank VW and custom drill them. I did find brake pads # DP4105r EBC i figure that is correct.
    I am getting some fading when i brake have yet to try to lock them up , not sure i can. I don't feel the fading it in the peddle but you do feel the trike it as you slow down.
    Any advise would be great!
    trike has just 14k for mileage and I thin the pads have been changed 1 time so far.
    Thank you,
    Bob
  2. Roadsmith banner
  3. #2
    Mar 2011
    mountain home,ar. USA
    I use the EBC Yellowstuff pads and have very little wear on them. If you check with the Summit Racing site there is a breakin procedure for the EBC pads which will help seat them correctly. I would suggest you check that out before you drive the trike with them so you can get started on the right foot.
    Also, RS rear brakes don't lock up the rear wheels easily and that is a good thing. Wet, off camber, loose stuff in the road would cause them to lock up without ABS causing a loss of control. Also, keep using front brakes! My experience with friends is they tend to get lazy about using the front brake and it makes a huge difference in how the trike stops.
    Good luck!
  4. #3
    Sep 2016
    Springfield, Mass. USA
    Thank you Mike, for this good information...
    So when, my times, come for new brakes I'll be ready
  1. Rear Brake Rotors for 2012 Triglide
    By MHFarrar in forum Harley Tri Glide
    Last Post: 06-09-2017, 10:04 AM
  2. Honda GL1800 with lehman trike rear rotors
    By warren in forum Lehman Trike
    Last Post: 02-18-2017, 09:42 AM
  3. Roadsmith HTS1800 Trunk
    By rogerm60 in forum Honda Trikes
    Last Post: 10-25-2015, 10:11 AM
  4. Roadsmith HTS1800 Trike Owners....need opinions
    By Haste Maker in forum Honda Trikes
    Last Post: 10-02-2015, 06:45 PM
  5. Rear brakes, need replacement rotors
    By flhtrider in forum Harley Tri Glide
    Last Post: 07-28-2015, 11:53 PM
